Trane XE100 and I am getting an icing condition resulting in a shutdown. The fan apparently was operating but not moving any air through the room vents.When I took a panel off the fan assembly I got plenty of air movement but also got the icing condition.
  • 148 Answers
Sounds like you are low on freon or you have some type of obstruction that is blocking the full flow of air across the coil.
Go for the simple thing first which is make sure you don't have something blocking the flow (like one time I found a plastic bag from the grocery store that had been sucked into the return grill and when the fan came on it would lay on the A-coil blocking the flow).
If that's not the problem then you are probably low on freon and should have the system charged.
Posted on May 19, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Tip
Water leak in split a/c.
When compressor pumps the vapor of the freon passes through condenser coil pipelines where the heat removed by fan and becomes low pressure low temp and then travels as liquid. By removal of heat in the room again the freon get vaporized and sent to compressor. In this cycling if your indoor coil is dust blocked the room heat can't be removed. resulting this the liquid becomes forming ice over the coil. And when it cut off by coil temp, the fan only will work and ice get defrosted and water spray thr' vent.Due to coil block and makes airlock to drain pipeline. Resulting to water leak inside.To avoid water leaking service your a/c periodically.
on Jan 10, 2011 | Heating & Cooling
My ac unit is about 20 years old. it is frosting up now. should i replace it or fix it.
alot of items can cause it to frost up. dirty evaporator coil, dirty impellers on evaporator fan, low on freon, trying to operate system at to low a room temperture will result in pressure drop to a point that will form ice.
Jun 15, 2015 | Heating & Cooling
I get this message when I turn on my laptop. It's almost a year old. "The system has detected that a cooling fan is not operating correctly. Continued operation is not recommended and may...
More that likely the fan is going out. Check the fan exhaust to see how much air it is moving if any. A laptop cooling pad will probably help out and possible prolong failure. If its under a year old, the maufacturer may fix it for you. You'll just have to contact HP and see if they will, or if they can get you a new fan to replace yourself if they wont do it for you.
Sep 11, 2011 | Computers & Internet
The refrig on my trane xl1400 unit is not getting cold...the fan runs and I do not see icing?
compressor is either not running or out of freon, need to verify if compressor is operating by removing access cover's and using an amp probe clamp, verify that the compressor is operating, if not check electrical connections and capacitor which is required to start and run the compressor. Capacitors have more common failure rate than any other component.
Aug 23, 2011 | Heating & Cooling
I have a 20 year old Trane heat pump. Outside
Yes, you will want to put the unit into cooling mode to help assistance with the ice melt.
If you can, block off the outdoor coil or disconnect the outdoor fan motor. This will assist in raising the discharge pressure and temperature and thus, it will melt the ice quicker.
Or, if you have the capability, you can take a garden hose around to the unit hooked into hot water and melt the ice that way.
If your control board is messed up, why aren't you replacing it?
Jan 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My Trane air conditioner is not blowing cold air
there could be a few things low on freon will cause the coil to ice up and no air can get through,breaker or switch to the blower unit in the house is off belt broke or the moter let go
Jul 05, 2009 | Ruud Central System Air Conditioner
Trane air handler cycling rapidly
Depending on the age of your Trane unit. The fan relay has a time delay. This is a solid state board on the relay. Most of the time they stick on or off. Check for loose wires. But start with relay.
Jun 03, 2009 | Heating & Cooling
Say me certain reliable brand gas air conditioning for home
Goodman, Trane, and Amana are all pretty good manufacturers of heating and air products with some of the best warranties available.
Goodman: www.goodmanmfg.com
Trane: www.trane.com
Amana: www.amana-hac.com
Hope this helps.
May 27, 2009 | House Brand Heating&Air Conditioning...
Heating & Cooling Logo
271 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
