Question about Bosch 23 in. SHU33A Built-In Dishwasher
Wont drain check everything push drain botton still wont drain
Model shu33a its 3 years old
I call a repairman in it was the drain pump thank you for your help NOT what a joke this site is have a good day boys
Posted on May 19, 2009
I own a Memorex DVD player, model MVD2030 which hasn't been used for 6 years (when I moved). Tried to set it up today and find the "open/close" button does not function. Any ideas on how to resolve this...
its not problem at all.
if you have an old stereo or tv set you can use one of the small push botton to replace it.
you will need screw drivers, solder, suction and some patience to do the job. that is if the botton is making bad contact.
the problem can be a bad driving IC.
try to open the casing, locate the open/close motor, turn it manually to fully open tray. plug the set into power and try to close the tray. does this happen and still the tray wont open with the botton, then your driving IC is bad. i dont know if you can change the IC, its small and maybe and SMD.
Aug 26, 2010 | Televison & Video
My bosch dishwasher model shu33a keeps running.At first the sanitized light would not light now it just keeps running and when i open the door its not real hot like before..the washer is only 3 years old.
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Feb 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My bike won't start
First make certain the fuel is fresh ,and drain any old fuel out of the carb ,small screw at the bottom of the float bowl.when dry turn fuel on ,if flow starts again no blockage .start bike now,if no fix, remove spark plug if it is dry the carb is blocked . touch plug to cylinder head and start be carefull not to shock yourself use pliers . If no bright blue spark check side stand cut out switch ,kill switch . if the battery has been left uncharged for more than 2-3 months replace as wont work well. to check for seizure remove plug and push bike in first gear you should hear and feel the engine turn.
Feb 14, 2010 | 2005 Yamaha WR 250 F
My pc cannot turn on.
Get yourself a new one with new power supply new quad core new hard one terra evething new for a few dollars time change computers are something very different nowadays nothing to do with 10 years old machines....enjoy todazy life is not forever...;
Aug 19, 2009 | HP Hewlett Packard Pavilion Slimline...
Gsxr 1000 3 years old
Try draining all the old fuel out and running fresh fuel through it.Dont try to dilute it as stale fuel turns acidic and corrodes everything it is in contact with.Fuel system may require complete clean out
Dec 09, 2008 | 1994 Suzuki RF 900 R
DVD drive
Good day!
Let's try to open your dvd manually. Look at your dvd drive you will find a small hole just beside the push botton, find a long pin push that pin side the hole, it will open you dvd. Push the dvd botton and try to open it again.
Thanks.
Nov 01, 2008 | LG Computers & Internet
Bosch SHU33A won't drain
I believe you, but did you check the nipple on the drain where the hose connects?
My sink drained OK, and when I took the dishwasher hose loose from the sinkdrain it drained great into a bucket.
When I stuck a screwdriver down where the drainhose connects to the sinkdrain, I felt all kinds of resistance. Its now cleaned out and the dishwasher drains again.
Hope this is your problem otherwise you may need a new pump.
Apr 07, 2008 | Dishwashers
Broken dishwasher
I have a kenmore model 665 168 29000 the mounting bracket have broken from under the cabinet, so when you open the door and pull the racks out the machine moves forward, how can i fix this?????
Mar 08, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch 23 in. SHU33A Built-In Dishwasher Logo
288 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
