Question about YIBOO Toys
Yiboo UJ317 NEW, NEW BATTERIES, WILL NOT CONSISTENTLY RESPOND TO THROTTLE, UNABLE TO FLY, TURNS ON AND OFF, CONTROLLER ISSUE?
  • Mach1Airspace
    Mach1Airspace Mar 05, 2014
    Have similar problem with mine - the radio sends a signal but there's no smooth increase in blade speed, just a punch to lift off speed and a sudden shut off instead of a slow RPM decrease.
skaterkid307
  • 86 Answers
SOURCE: tv doesn't respond to remote controller
This is caused by radio frequency and what i mean by that isyour tv unit is gettng confused with the crystals that control the connection between the tv and remote.The solution to this is to go to wal mart and buy a new universal remote and in the package should be an instruction manual to set the remote to the tv , First find your tv name in the pamplet,second there will show a code of the remote type it in and enjoy.
Posted on May 18, 2010
SOURCE: right out of the box
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Posted on Dec 28, 2010
bigguy810
  • 448 Answers
SOURCE: FXD RC Helicopter - helicopter
check your controller some of them have a a.b.c switch for different channels look it over good
i have 5 rc helicopters i just bought the 3ft sky king and it has a a.b. switch on the helicopter
hope this helps you
bob
Posted on May 23, 2011
hbsurfdawg
  • 95 Answers
SOURCE: the helicopter does not fully charge
You mention the controller, new batteries are good for the controller, but you need to have your heli batteries to be charging correctly. If you get new heli batteries, then Check your charger, it is probably not putting out the right voltage.
e
Posted on Nov 19, 2011
  • 43127 Answers
SOURCE: Symptoms are either controller isn't transmitting or copter isn't receiveing
SORRY but after all it is a toy .
Posted on Nov 19, 2015
My yiboo elicopter not respond from radio control
need new radio to try to match it translate this letter or receiver on the helicopter
Nov 29, 2014 | YIBOO Toys
My yiboo heliocopter uj4702 wants to fly backwards.
you have stuck up controller and receiver contact points, means you need to check both on the controller and the copter where the stuck up sensors are, or you may recalibrate your controller, reason why you push throttle forward but will not fly forward.
Dec 27, 2013 | YIBOO Toys
Need to find out what model of yiboo helicopter this is to find the blade
Measure the length and width of the blade you have and then go on line to the Yiboo Helicopter website and talk to the technicians. Have the helicopter handy if they have other questions..don't forget to ask them for a parts list for your model (You'll need it if you fly it)!
Dec 28, 2012 | Toys
The helicopter does not fully charge
e
Nov 19, 2011 | Toys
Hello, just been given a syma s006 for xmas, charged it up for max 110 mins as indicated in manual, though LED never came on to indicate full charge. LEDs do come on flashing when switched on at model. New...
try this,switch the helicopter on,then make sure the left controller stick is fully down then turn the controller on,move left stick fully on then fully off should be ready to fly,have fun
Dec 27, 2010 | xheli 3 Ch Syma S006 Alloy Shark RC Remote...
Me and my dad have 2 yiboo Uj4708 helicopters. We need to know how to change the frequency on them so we can fly them simotaniously. We can change the frequncy on the remotes, but don't know how on the...
Turn both helicopters and remotes off. Then switch the remote to another channel, either a,b, or c, turn on HELICOPTER FIRST, turn on REMOTE second. Move throttle up and down, helicopter should start responding.
Dec 26, 2010 | Toys
Right out of the box yiboo uj 381 r/c helicopter. Copter charged and new batteries in the controller. Lights flash on the copter and flashing light on the controller but nothing happens. what's wrong
Dec 25, 2010 | Toys
TV doesn't respond to remote controller suddenly. I changed batteries of the controller and checked it. The controller is not a problem. I tried manual buttons on TV but it didn't work. TV turns on and...
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Yiboo ch-47 rc helicopter: Rear rotor has reduced lift, does backflip when attempting liftoff. Rear rotor turns more slowly when tapping the "collective" on the RC. Took skins off, all 4 shafts turn...
If you twist its rotors a little more then the lift can increase. But try to twist then only if they could be else you may become minus them and I would hate it.
Feb 26, 2010 | RC Remote Control Helicopter Ready To Fly
I need a schematic for the x-treme scooter
Check the batteries, they need at least 12+volts to run scooter. Blinker may be burned out or the wire came loose. If batteries are charged Two things That could be wrong are: Twist throttle is NO Good, Or the controller is BAD. You need a voltage tester, (Disconnect the Wiring Harnesses) and check voltages coming out of the controller(the silver BOX with lots of wires) and see if it is sending voltage to the twist throttle. Controller wires to the Twist throttle should read 4-5 volts.
(Make Sure You Unplugged That Wiring Harness) There is 4-6 wires in that Wiring Harness then find + and - test them for voltage from that Controller box wiring harness. If You get a positive reading out of that Controller wiring harness then the Twist Throttle thing is bad. If you get NO READING out of that Controller Wiring Harness Then if is BAD. Normally it will be the dead batteries or the Twist Throttle that go bad. Batteries are expensive, Twist Throttle Cheap. Good LUCK
Apr 03, 2009 | Electric X Treme X 360 Scooter
Toys Logo
46 people viewed this question
Top YIBOO Toys Experts
ray gallant
Are you a YIBOO Toy Expert? Answer questions, earn points and help others
