Home | Zenith | XBV442 DVD Player / VCR Combo | Sometimes after ins...
Zenith XBV442 DVD Player / VCR Combo
Problem for Zenith XBV442 DVD Player / VCR Combo
Sometimes after inserting a DVD into my Zenith DVD
By barb_bilbrey on May 18, 2009
Sometimes after inserting a DVD into my Zenith DVD player and start playing it it plays for awhile and then freezes every so often. What can I do?
Best Solution
posted on May 19, 2009
Very Helpful)
stoneheaded
Rank: Guru
Rating: 91%, 575 votes
The problem with the unit is the drive circuits are locking up either from overheating or aging. If in warranty send it in for service. If not in warranty look in your owners manual for the Zenith website and check the frequently asked question and troubleshooting sections. See if someone has posted this problem and gotten a solution. If not call the technical service telephone number and get technical help with your problem. You can also try opening, your unit and looking at the drive circuit and dvd carriage to see if the accumulation of dust and dirt has caused a problem with the operation.Use compressed air and clean out the carriage and around the circuit boards.Only work on the unit with the power off and unplugged for your saftey. You can also try using a fan to cool the internal circuits of the unit. It may just need better air flow. You should clean and check the laser and carriage every six months to make sure it has not accumulated dust and dirt that may affect the units operation.To clean the laser use cotton swabs and a small amount of isopropyl alcohol. Rub the head of the swab across the laser head gently until it looks clean and shiney.You may want to use a little lithium grease to lube the carriage and gears. Also check all belts for wear. I hope this helps you with your problem.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Zenith XBV442 DVD Player / VCR
Questions and Unsolved Problems for Zenith XBV442 DVD Player / VCR
Do you recommend Zenith XBV442 DVD Player / VCR Combo?
Answer
Answer
how to change the time on old zenith vcr #s/n68050603
Answer
how to connect my zenith xbv442 to a directv hd receiver
Answer
Re: Zenith DVD/VCR combo XBU342 I can't get the DVD to eject. Any suggestions?
Answer
esta bloquedo no sebe las pelicula en el dvd solo tiene audio
Answer
esta bloquiado no sebe las pelicula en el dvd solo tiene audio
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zenith XBV442 DVD Player / VCR...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
