Question about Bissell 6591 Power Trak Revolution Bagless Upright Vacuum
Bisell power trak revolution motor not working
Machine no power seems very hot
Vacuum cleaners easily overheat and will shut off as a result. The cause may be a bad electric connection, electric cord or accumulation of hair on the roller bar (prevents the bar from spinning, which burns up the motor). It might be a temporary problem or the motor might have burned up. Let it cool down, check all cords and connections carefully and retry it. You can call Bissell 1-800-237-7691 for more help if this doesn't resolve it
Jan 26, 2016 | Bissell 6591 Power Trak Revolution Bagless...
Bissell 6591 operating twice as loud as before.
Hey Mike! Excessive noise can be contributed to dirty filters or clogs. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Feb 03, 2013 | Bissell 6591 Power Trak Revolution Bagless...
Bissell powertrak revolution dirt not going into cup
If the unit is not blocked between pickup and filter have a good look at the filter to see if air is passing through it---paper throwaway or foam filter the can be washed?
The ones that can be washed etc will have instructions right on them.
Nov 02, 2012 | Bissell 6591 Power Trak Revolution Bagless...
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
The brush is clean and spinning but it isnt picking up anything and just pushing pet hair around.
You mentioned pet hair. Remove the brush cover and check for a plug (possibly pet hair). Sounds as though you have a plug somewhere and it's not allow the suction to pull it through. Also check your filter and clean or replace as necessary. Hint; Never let you container get over half full, it reduces the suction.
Nov 02, 2010 | Bissell 6591 Power Trak Revolution Bagless...
Rotating Floor Brush will not rotate. The Drive Belt is not broken and the Motor Pulley appears to be rotating.
I did not receive a solution to this problem. I will be purchasing a new vacuum (probably not a Bissell) to resolve this situation. Thank you.
Jan 21, 2010 | Bissell 6591 Power Trak Revolution Bagless...
Motor seems like it is overworking. The sound of the vacuum is higher pitched than before.
Hi!  Almost certainly your vacuum has a blockage somewhere. The higher pitch means the motor is running faster than normal, but it's not overworking, it's actually working less because it's moving less air.  Check for blockages and clear whatever you find (your user manual should tell you where and how to look), and that should be that! Alternatively, it may be that the drive belt to the brush roller has broken. Check that too. I hope this helps.  If not, please write again and I'll try again.
Feb 28, 2009 | Bissell 6591 Power Trak Revolution Bagless...
Bissell 6591 Power Trak Revolution Bagless Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
