Question about MEElectronics Audio Players & Recorders
Headphone works only on the left in Bluetooth mode but both sides are working with a cable.
SOURCE: The Right side does not work.
i just bought the turtle beach x1's and had the same problem only it was the left side not the right and i was pushing the green audio connector cable to close together with the av componet connector and just slightly removed the audio cable from the av connector cable basically just slightly remove the headphones from the connection port on whatever you are connecting it to if that dosent work then most likely you have a lose connetion port on your device and will need to replace it or replace the device alltogether if the port can not be replaced.
Posted on Jan 30, 2010
  • 24 Answers
SOURCE: Left side of my Headphone
First play with the wire at the phone plug end and where it enters the ear housing;wires usually open up where they flex most.The next step requires access to the actual speaker connection inside the left housing.You'll need to disassemble it to get to the soldered connection.Use an ohmmeter to check for continuity to the phone plug end.Check both wires;signal and ground.If both show continuity,it's your speaker.The speaker should have a low resistance reading,not open.Also try another set of phones;if that doesn't work either,it's the source.
Posted on Aug 02, 2010
msovesky
  • 62 Answers
SOURCE: In my Bose in ear
IF you are good at soldering, you may be able to open it and reattach the wire, otherwise, you need new headphones. Sorry
Posted on Feb 28, 2011
  • 5 Answers
SOURCE: boss oethe left side of my headphone is stop working
Try putting the output reciever into your ****.. Then put the earphones on. If you dont hear anything you might want to bring it back to the retailer and explain that your test proved them that it dont work.
Posted on Jan 18, 2012
  • 246 Answers
SOURCE: left headphone not working
what is the source of the audio? I would start by checking that first. switch sources to see if the transmitter is the problem if the transmitter is only getting the right side signal, that's all you'll hear...hope this helps!
Posted on Jun 13, 2012
Why wont the left headphone make as much sound as the right?
The headphone could be defect, or the device you did connect it to.
Mar 15, 2015 | LG Electronics Tone Ultra HBS-800...
Bluetooth headset and headphone jack same time
They're designed to work one at a time. I'm not sure if you could do this with tweaks, but you're going to have to root your phone for that (and you may void your warranty by doing that.)
Feb 02, 2014 | Cell Phones
I can hear only from right headphone of my sony bluetooth
Either the left headphone is shot or the headphone jack is messed up. Try a different set of head phones if its same result see about replacing the jack.
Jan 23, 2014 | Sony Walkman Audio Players & Recorders
Right side of headphone stoped working
you need to open the broken side up and re solder the cable back also check the other cable to see if it hasn't sheered off inside the insulation like mine did. Hope this helps. J
Feb 17, 2013 | Philips SHB9100/00 Bluetooth Stereo...
Iphone 4 music plays via bluetooth but not via dedicated cable connection
It would seem that the headphone jack is damaged. Double check that the wired headphones do work.
May 08, 2011 | Cell Phones
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
Jan 30, 2010 | Skull Candy Lowrider Headphones
Headphone output distorted on one side. Replacement jack?
studiospares (in london) or radioshack in USA, unscrew and get busy with a soldering iron, its not too hard, only 4 cables.
Jan 22, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Left headphone does not work properly
Based on your post/description, it would seem that the cable of your head phone developed an open circuit somewhere. I would assume it is pretty near the headset itself. On most occasion, it is at the very entry point where the cable goes into the headset.
Normal repair would involve opening the side casing where the cable enters the headset, cutting the cable about 3 inches from entry point, strip exposing the three or 4 wires and reconnecting inside the stripped ends. Effectively what you have done is trim the cable a bit shorter eliminating hopefully the intermittent section.
Hope this be of help/idea, Post back how things turned out or should you need additional information.
Good l;uck and kind regards.
Oct 27, 2007 | Logitech 350 (980374-0914) Headset
18 people viewed this question
Top MEElectronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MEElectronics Audio Player and Recorder Expert? Answer questions, earn points and help others
