Question about Ricoh Aficio SP C231SF SPC231SF SP C232SF Aficio 232SF Lanier SP C231SF SP242SF Cyan Toner 4
ERROR 13B523 ON LANIER SPC231SF WHEN TRYING TO FAX
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
How to replace waste toner bottle on lanier SPC231SF
can u mention the model number of lanier copier
Jul 26, 2014 | Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Canon Fax L220
From previous experience it is a compatability problem stemming from propritary transmission modes. Not sure what model Lanier fax is but they can disable some optional transmission modes first. Otherwise if this person is important you can tell that person to force transmit to you at 9600bps.
May 11, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Ricoh Aficio SP C231SF SPC231SF SP C232SF Aficio 232SF Lanier SP C231SF SP242SF Cyan Toner 4 Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
