Question about Canon imageRUNNER C6800 Copier
IR 5870Ci Errors: E000748-4021 & E000020-03a8
Got this iR 5870Ci MF Canon printer which randomly gives me the Error code E000748-4021 then asks me to switch it off and on again.
I can't find anything on google for this error report so any help would be fantastic.
It also likes to give this error code: E000020-03a8
My printer support company tells me its something to do with our network but as these errors occure when its not connected to the network i find this hard to believe.
Cheers
  • 58 Answers
E748-4021 means the SERROR signalof PCI has been detected
solution:disconnect and then connect PCI board if the fault persists ,replace it or the main controller pcb
Posted on Aug 07, 2009
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
How to clear e000067 for canon irc2880i copier
Are you looking for Canon printer support number to sort out issue related with your printing machine? We also provide the Canon Printer customer Support, Canon Pixma Support Number, software installation, software upgrade, cartridge jam, paper jam issues and much more. Canon Pixma Printer Support
My canon ir 5000 is giving me error 733 0001. What could be the problem?
Hi Felix,
Try searching online for "error code **** + your make & model" You'll turn up some good hits. Try. http://fixyourownprinter.com/forums/printer
Aug 08, 2015 | Canon Office Equipment & Supplies
Please tell about error code E000732-0001 of canon ir 5870ci photocopier machine.
Dear
This symptom occurred because the Reader Controller PCB was fault.
Remedy
1. Make sure that the connector between the host machine and the reader unit is securely fitted.
2. Make sure that the connectors on the Reader Controller PCB are securely fitted or there is no pinched cables. clean the contact points of FFC cable.
3. Remove and insert the Main Controller PCB (Sub) from the Main Controller PCB (Main). Also remove the RAM and clean the contact surfaces and re insert.
If the symptom still recurs, then replace the Reader Controller PCB with a new one.
Thanks.
Jan 20, 2015 | Canon Office Equipment & Supplies
Hoo.comi want to solve the problem in my copier canon ir 2016, error code e354
this is error code that isn't stated in service manual and doesn't have description. When this error occures the procedure is to report to Canon service center. The same errors were on ir1600/2000 series, but without some good explanations.
So, call authorised CANON service partner!
Sep 13, 2011 | Canon iR 2016i Black and White Copier
My printer canon 4412 not work the display showing on main switch e202-0002
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
Apr 05, 2011 | Office Equipment & Supplies
I have a canon copier ir 3035, its giving error code E000002-0000, whars the problem?
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Aug 21, 2010 | Office Equipment & Supplies
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
Canon imageRUNNER C6800 Copier Logo
1,096 people viewed this question
old marine
old marine
