Question about Hunter 23852 Classic Original Ceiling Fan
Hunter 22272-001 The fan hums but doesn't turn. (spins freely when pushed, oil level is fine) I can't find any parts diagram for this fan so I don't know if it has a capacitor.
hardrocko
  • 1476 Answers
SOURCE: 3 speed Hunter Fan only has 2 speeds
Assuming that the unit was wired properly from the factory and without being able to look at the switch I would have to agree that the switch is bad. The different speeds are obtained by having a different winding for each speed. If the unit was wired properly at the factory and never had three different speeds then the switch is not rotating between all the contacts. The switch should only be a couple of dollars and would certainly be a cheap solution to try. You can check the existing switch by removing it from the circuit completely and checking the continuity with a DMM from the input to each output as you switch it. Continuity should move from one to two to three. If not the switch is bad. If the switch checks out OK then you have a bad winding in the fan and probably need a new unit. Good luck.
Posted on Jul 12, 2006
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
clyde2j2
  • 137 Answers
SOURCE: Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
Posted on Mar 02, 2009
landsend
  • 1066 Answers
SOURCE: My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Posted on Mar 26, 2009
VtToolMan
  • 704 Answers
SOURCE: I need a hunter remote control unit part
This particular Hunter remote control unit has been known to have interference issues for some time now. It is very suceptible to picking up other transmissions, such as those from TV remotes, etc.
If you're having intermittent operation of the fan and/or light, you can try setting different codes for both the receiver and the remote.
That being said, the best source for a replacement unit is directly from Hunter, since you might also still be under warranty you might get it replaced for free, if you remembered to fill out and mail the warranty card!
Of course, if you just want to replace a lost or broken remote, give them a call and order one (or two and have a spare!).
To speak with a live Technical Support Representative call: 1-888-830-1326 (United States) 1-866-268-1936 (Canada) Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
Why don't fan blades rotate?
Sadly Hunter doesn't want people dismantling their stuff and replacing broken or burnt out pieces. They'd rather you buy a new one. If the motor has burned out which is possible a solution depending on how handy you are is simply hunt down a similar replacement and reconnect it.
Make sure the new motor has the exact same leads and connectors as the old one had as some Hunter fans have more than two leads. The model I have has four leads: a black, a white, a green and a red as my model has integrated lighting controls by passed by the motor.
I bought a simple blower motor with the same rating only two wires and with a bit of solder and wire I hooked up the motor and lights separately. The new motor is much faster than the older one so I had to add a tiny 1-way 500 watt dimmer switch to manually turn down the speed.
Aug 30, 2015 | Hunter Dryers
What to do if fan is frozen up
You need to put some Hunter oil then push the blades around by hand to get the bearings lubed. Then check oil level and add more oil if necessary.
Sep 25, 2014 | Hunter 23852 Classic Original Ceiling Fan
Goodman clt60-1 fan not working loud humm
The hum is a good indication that the fan is getting power. Therefor, the fan is locked up or it has a weak capacitor. Attempt to spin while power is off. It should spin freely. if not, you will need to replace the motor. If it spins freely, I would attempt to spin the fan blade while it is humming. If it starts running fine, it is very likely the capacitor. If not, then replace the motor.
Sep 08, 2014 | Goodman Heating & Cooling
Hunter 22272-001
If the oil is OK then check to see if it has a capacitor that might be going bad.
Dec 27, 2013 | Hunter 23852 Classic Original Ceiling Fan
A customer of mine has a very nice Hunter original ceiling fan that she never oiled and now the fan just hums and wont spin. Is it possible to repair after no oil damage is done?
Put some oil in and turn blades by hand to lubricate the bearings. If the motor is frozen, then you would have to take it to a service center or send back to Hunter for repair.
Apr 17, 2013 | Hunter 23852 Classic Original Ceiling Fan
Air condition motor not going on
check to see if the fan is running if not it has frozen up over the winter. turn off fuses to a/c unit then try to turn fan by hand,if not soak down fan bearings with penetrating oil like PB Blaster keepmoving fan blade back and forth until it spins freely. Then try turning on the power to a/c unit if motor then turns fan freely , shut it down again and use a good coat of a-1 motor oil (ELECTRICAL) on the fan brgs. This should get you through for another year or so. On the other hand if fan will not spin by the motor now but spins by hand then the fan motor is bad.
Apr 14, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Have an expensive Hunter indoor/outdoor pedestal Fan that stopped working. It just "hums" and does not turn. Please help.
With the fan UNPLUGGED, try to spin the fan blade with a pencil or something that will fit through the blade cage.
If the blade spins easily, there is an electronic problem (control or motor) that must be serviced.
If the fan blade is stuck or very hard to move, the shaft and bearing are probably dirty and need to be cleaned. You can temporarily fix this with a tiny amount (a drop) of WD-40 applied to the shaft where it enters the motor. Spin the blade manually to work the oil into the bearing. If the motor spins freely, the dirty bearing condition is verified. To properly clean the shaft and bearings, the motor must be disassembled.
Jun 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
My outside unit fan doesn't spin. i hear a clicking noise and a humming but the fan won't spin. i've tried to spin the fan and it spins freely by hand.
You may need a new start capacitor or fan motor.I would have the capacitor checked by a electrician and changed if needed. Good luck and thank you.
May 31, 2011 | Ruud UAMB Air Conditioner
Older hunter original, needs lubrication. Where do I put the lubrication in? What kind of lubrication/oil? Used to buy fan oil, but no longer available, Fan has clicking noise and lubrication oil...
Howdy,
This is the owner's manual to your fan
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41121.pdf
As for oil, you can use one of two oils. Depending on how old your fan is, I suggest changing the oil by removing the fan, turning the motor completely over and letting it drain into the "dish" on the part that spins, clean the oil out of there, then re-hang the fan and oil with 1 oz of either Hunter Fan Oil (which is available from hunter, or on ebay, just search for Hunter Original Fan) or Zoom Spout Oiler, both are the same oil.
Thanks
Sep 23, 2010 | Hunter Dryers
Model # yg2047b. I had this fan installed in June, worked fine,now it hums..what could the problem be?
If the fan does not spin and the motor hums, you have a stuck rotor. It may be due to bushing/bearing alignment problem or a lubrication problem.
Try to spin the fan blade manually. It should turn freely, otherwise the rotor is stuck. Remove fan blade and put few drops of lubricating oil on the bushings/bearings and manually turn the shaft to free it up. Alignment of shaft and bushings/bearings must be after lubrication is done and the rotor is still stuck. Move the shaft up and down and side to side until it smoothly spin when manually turned.
Aug 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hunter 23852 Classic Original Ceiling Fan Logo
42 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
