Question about Vizio M470NV 47 in. LCD HDTV
Need screw size vizio m470nv pedestal stand - Vizio M470NV 47 in. LCD HDTV
budmrtn
  • 11361 Answers
SOURCE: I need to attach a
They are Metric screw either M4, M5 or M6, you can get them at HD or LOWES for about 35 cents each. The length of the screw should be about 3/8 inch beyond the screw hole.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 01, 2010
  • 6 Answers
SOURCE: Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Posted on Mar 31, 2009
SOURCE: I will be watching my vizio m470nv and it will
I hope you get a response. I am having the same issue. It turned off on my this morning @ 0600 and then after getting home from work I was cooking dinner and was wondering who turned the TV off. It did it again.
Then it happened about three hours after that. I wish I knew what the problem was!
Posted on Jun 25, 2011
  • 302 Answers
SOURCE: vizio l32 tv stand screw size
The best thing to do is trial and error. Get some sample screws from home depot.
you can get parts for this tv at www.interliquidparts.com
Posted on Feb 25, 2012
SOURCE: Lost my Vizio VO42L base stand screws (8). Can I
The exact size for this and almost all visio TVs are: M4 x 35mm at .70 pitch
Hope this Helps the next guy/gal that looses their screws...
Posted on Jun 16, 2012
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
What size screws do i need for mounting a vizio 55" to a stand?
This depends on the model being hung on the stand. The size screw to use is usually listed in the manual. Also make sure to check the maximum length of the screw or you can damage the TV.
Dec 03, 2014 | Vizio Televison & Video
How i fix my wobbly high chair
If you know someone that has a welder they could weld it . Or if you don't .and can get the pedestal loose from the base you'll see where the break is .I would cut a piece of plywood drill a hole in plywood the size of pedestal push it in plywood stand stool up push down . Till pedestal touches floor take drill .get some 1" self drill/tapping screws commonly called : TEK-screws put 3 screws in the wood at an angle so screws go into the pedestal to hold it tight paint or stain the wood.your handy work.
May 15, 2014 | Furniture
Vizio base stand model vx37l
You can get replacement Vizio remotes from Walmart, $10. As far as the pedestal, I can't locate one either. I would suggest checking Ebay frequently. I recycle LCD sets and come across rare pedestals. If you would like, visit our website, click on Contact US and leave your contact info. I will put you down on our Wish List and contact you if we get the pedestal in stock.
www.back2lifeelectronics.com
Jan 10, 2013 | Vizio VX37L Television
Toshiba 40rv5252r stand screw size
I called Toshiba for this TV model "40RV525R" and they said the pedestal stand for the t.v. to stand on was an m5, product # 75012791, and the length was approx 20-25 mm
Feb 11, 2012 | Toshiba 40RV525R 40 in. HDTV
Video board failure vizio M470NV
Vizio M470NV is an economy class LED TV made by Sharp for Vizio.
The main board in it suffers from a few problems that are actually common for the Vizio LED TVs made by Sharp and based on the same design and built with the same pool of components.
It took time to TV repair shops, but now repair services and possibly even exchange boards are starting to become available.
See here for more details:
http://www.coppelltvrepair.com/p/1354/repair-service-for-3647-0302-0150-main-board-for-vizio-m470nv-smart-led-tv-totally-dead-blinking-endlessly-or-otherwise-failing-to-start
Hope it helps!
Jan 16, 2012 | Vizio M470NV 47 in. LCD HDTV
Where can i find a stand
If you're referring to the original pedestal base sold with the TV, your best bet would be Ebay
or Craigslist.
On Ebay, search in the Category: Electronics > A/V Accessories & Cables > Mounts & Brackets >
using the search string "vizio 50 pedestal stand" or "vizio pedestal stand base" and you should get a few matches. For example, this used pedestal stand, which has a current bid of $9.99 USD, or this new pedestal stand, being sold for $149.99 USD or Best Offer.
Hope this helps!
Jan 08, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Vizio M470NV 47 in. LCD HDTV Logo
150 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
