Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Printer won't recognize the new ink cartridges.
I replaced the ink cartridge now the printer says it doesn't recognize it and I can't do anything now, they are sending me a different cartridge to try. Is there anything else I can try to do in the interm?
  • maswan May 20, 2009
    Thank you for your suggestions, I will try trimming and cleanig and wait for the new cartridge to come. I appreciate your help.
    Marilyn
  • 30 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-20
Posted on Sep 04, 2009
  • Epson Master
  • 419 Answers
Unfortunately there's not a lot left while you wait for the delivery... If the printer is refusing to recognise your cartridge it's most likely that the chip is incompatible but here's a couple of possible solutions while you wait.
  1. Remove the problem cartridge, clean the chip on this cartridge and check for any overly excessive plastic securing the chip in place. Sometimes the plastic can push the contacts away or redirect them so careful shaving of any excess material may help.
  2. Check the slot the cartridge goes into for any damage to the contact wires. These are very thin and VERY delicate wires in the front of the printhead carriage. If they are damaged or soiled you need to consider a warranty replacement or accept you could break things if you try to fix them yourself. Hopefully this isn't the problem
Beyond that there's really not a lot else left to try..
Best of luck.
Posted on May 19, 2009
Windows 7 doesn't recogize new ink cartridge on HP C6280
I would go to HP and update the C6280 printers drivers. It sounds like there is an issue with the driver. It there is not an update then I would uninstall the driver and reinstall.
Jan 19, 2013 | Dell Inspiron Core i7 640GB HDD
Does not accept new ink cartridges, indicates they are empty
This might ba an issue with the cartridge holder in which its not recognizing inks or inks are defective. Call Epson for cartridge replacement is reinstalling of inks doesn't work.
Sep 21, 2012 | Epson Stylus Photo 950 InkJet Printer
Canon printer won't recognize new ink cartridge
did you take the shipping tape off of the cartridge? It's usually the one covering the contacts located on the underside of the Cartridge that is inserted into the receiver of the cartridge. Other wise, you may have a bad cartridge, if so, bring it back to where you purchased it and get another one. Chris Chrisab123@live.com
Feb 28, 2012 | Canon PIXMA MP160 All-In-One InkJet...
My HP DesignJet 500 plotter printer doesn't recognize any of the 4 ink cartridges
>Your have new cartridges,not refilled right?
>Remove cartridges,
>Remove right door,
>Check ISS unit cables,PCB & connectors as shown in snap shot,
Most of the cases ISS arrested with ink leakage from cartridges, result connectors,PCB tracks & cables got damaged.. check perfectly if found shoot the problem....
> Replace ISS unit,, But only professionals can do the replacement..
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm will loose their memory..be careful..
Dec 05, 2011 | HP DesignJet 500 InkJet Printer
Hello. My Epson Stylus CX 4200 now flashes the letter E and all the lights flash, including "error." How do I get it working again?
here's what you can do:-disconnect the printer from the computer-turn off the printer-inspect for anything foreign inside like jammed paper-turn the power back on-remove the ink cartridge-check the chip connnector at ink tank and at head carriage. If its dirty clean it with soft moist cloth. -check the status monitor. which ink tank not recognized. -press ink light (1-4 times) depends on number ink tank not recognized, press 1 time again, carriage will move co replacement position, unplug and plug again all ink tank, press ink light 1 more.
if that doesn't work, replace ink cartridge ONLY if you have a spare. DO NOT BUY new ink as the printer is bound for repair.
Nov 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I have a Canon iP6700D. I refill my carts. I have a resetter and use it every time. This time the printer won't recognize the magenta cart. I refilled it, reset it and replaced it as always. I...
If your printer did not good in times of reseting the cartridges do check the cartridge holder if the is some dirt inside or the terminal of your cartridge had wet by the ink when you refill the ink of your cartridges.
Aug 12, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
I installed new b&w & color cartridges and the
in your printer try to press on the restart button and hold it for about 8 to 10 seconds. by the way the ink cartridges that you installed are the genuine ink cartridges, if not then its gonna be normal that it won't detect as new.
Jul 11, 2011 | Dell Office Equipment & Supplies
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
185 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
