Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
HAVE A JOHN DEERE 318 LAWN TRACTOR, CHANGED POINTS AND CONDENSER, WON'T TURN OVER, TRIED STARTING FLUID IN CARB AND NOTHING. CAN IT BE THE COIL AND HOW DO I CHECK? THANKS
  • 69 Answers
Check the coil impedance on the primary and secondary side. You'll have to disconnect the battery negative cable so you don't short something out. Unplug the spark plug wires and the two sets of smaller wires connected to the primary side of the coil. The primary coil reading should be between 3.7 ohms and 4.6 ohms while the secondary (spark plug side) should be between 34.2 k-ohms and 41.6 k-ohms. If the resistance values you measure are outside of these ranges, you need to replace the coil.
Posted on May 19, 2009
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
318 dies after it runs for 20 minutes. It cools down and start up and runs for awhile longer. Has been into the dealer twice and still has problem. Coil and condensers have been changed. Tractor runs...
On the later models with the 220 series engine you would have a trigger/pickup coil mounted just below the stator with 2 screws.After reaching full engine temp the coil will short out.This has been a problem for the later 318's.On the earlier models with the 218 series engine (the one with points)I would suspect the ignition module under dash.
Sep 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I'm wanting to change points & condenser
At that age, it's highly likely that there aren't any! You don't say what engine is fitted, but if it's a Briggs or a Tecumseh, they went solid state in 1982. If that's the case, just replace the coil module.
May 12, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
BEEN RUNNING ROUGH WITH LESS POWER THAN BEFORE. NOW WON'T START AT ALL. NEW PLUG, CHANGED OIL AND FILTER, HAS A GOOD SPARK.
1956 420 john deere new plugs, wires,cap,plugs,rotor,points set on 20.condenser good blue fire on points and plugs carb rebuilt BUT want start you can pull off it will start and run
Sep 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have a older mmodel 318 riding mower with an onan motor. wruns very well but when it is hot outside it will shut down withinabout a minute the power will reinitiate and the tractor can be restarted ....
possibly a carb or coil problem. does it have point type ignition? if so try replacing the condensor.if nothing else changes try replacing the fuel filter. then nothing,a float sticking in the carb or a bad coil.
Jul 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
No spark
did you make sure the gap was set right on coil & flywheel it should be .020 between magnet on flywheel & the coil & the same thing with the points in the open possition between points & condensor
Jun 07, 2009 | Garden
JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
May 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Apr 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
457 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
