Question about Apple iPod nano
Can't turn off the hold status
Even after moving the switch, the hold status stays.
how can i reset it
  • 21 Answers
One think i would do is to try to kill the iPod all the way (by draining the battery) so it has no power.
then try charging and turning it on again.
additionally, you can also try to hold the "menu" and the center button down.
Posted on Oct 17, 2007
Instruction manual
Which model ipod ??
In keeping with Apple's goal to make user-friendly, streamlined products, the designers of the iPod built in easy-to-use reset functions into each iPod model.
Resetting the iPod is similar to rebooting a computer as all songs and data stored on the device stay there, and only temporary information (such as which song is playing) gets reset.
Follow these steps to reset an iPod.
Toggle the "Hold" switch to the "On" position, then "Off."
The "Hold" switch is the small sliding switch on the top of the iPod.
Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle.
Hold the "Menu" and "Center" buttons.
Press the 2 buttons at the same time for between 8 and 10 seconds.
Your screen will go blank and then boot up with a dark Apple icon.
The icon eventually turns bright and brings you back to your main menu once the reset is complete.
Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process.
Scroll Wheel and Touch Wheel iPods
Move the "Hold" switch from "On" to "Off."
Press the "Play/Pause" button and the "Menu" button at the same time.
Press both buttons together for approximately 6 to 8 seconds.
This initiates the self-running reset process.
Make sure the reset was successful.
If problems persist you may need to perform the reset process once again.
iPod Nano
Move the on-off switch to the "Off" position that shows the green strip.
Leave the iPod Nano in this position for 5 seconds.
Move the switch back to the "On" position.
Use your iPod Nano to make sure the reset worked properly and all your music is intact.
Aug 06, 2013 | Starlite Nextplay Fashion iPod Docking...
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Stanley 300 amp jump-start system status lights don't work. only low stays on
Sep 26, 2012 | Stanley 300 Amp w/12V USB Jump Starter -...
How do I reset the computer after changing the battery in my 2004 mini cooper S? The car started three times. Now it won't start even though all of the other electrics work
Turn off ignition. Press and hold the trip reset button, then turn the ignition on (don't start the engine), within 5 sec the SIA status will be displayed. Release the reset button. Press and hold the trip reset button for 5 sec, "rst" will be displayed. Release and re-press trip reset button.
The new status should be displayed.
Oct 02, 2011 | 2004 Mini Cooper
Hello excactly on christmas day my sansa e250 stoped responding, it turns on but it does not move on to the home page of the player, the screen stays at the sandisk screen, then it fades for about 2...
Try to do a reset, follow these instructions if this does not work. Reseat the battery.
Resetting your player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Dec 25, 2010 | SanDisk Sansa e250 MP3 Player
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
How to start the mp3 player to play
The player has to be reset. To reset slide the on switch to on and hold for 10 seconds. The player will reset, then just turn it on.
beaterman
Mar 12, 2009 | SanDisk Sansa e260 MP3 Player
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Service error code
C3451 Heat. Heater Trouble • The Heating Roller Thermistor/1 (TH1) and the
Heating Roller Thermistor/2 (TH3) fails to raise a
given degree of temperature even after the lapse
of a given period of time after the Heating Roller
Heater lamp/1 (H1) is turned ON.
• The detected temperature of the Heating Roller
Thermistor/1 (TH1) is lower for a given level of
degree than one of the Fusing Pressure Roller
Thermistor/1 (TH2) after the Front Door is opened
or closed, the Main Power Switch is turned ON or
TROUBLE RESET is implemented.
• The counter value of zero cross signal input is not
updated for a given period of time.
To reset:
Functions • If the all troubles occur and the status would not be cleared by turning Main Power
Switch OFF and ON again, or opening and closing the front door, clear the status of
the machine.
Use • To be used when the status would not be cleared by turning Main Power Switch OFF
and ON again, or opening and closing the front door in case of a trouble.
Setting/
Procedure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Jan 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Apple iPod nano Logo
22 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Mohamed Ismail
Mohamed Ismail
woodzowl307
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
