Question about Onkyo Televison & Video
Onkyo rc-660s remote control slow response
The remote works but I can only change the volume by holding the volume button down for a protracted period of time. Batteries are new
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
  • 280 Answers
SOURCE: Onkyo RC-649M remote
Remove any screws you can see and pry the case open. you will see a rubber pad and a circuit board. Clean both with alcohol and dry. reassemble and it should be OK
Posted on Jan 23, 2009
SOURCE: remote won't work
Hi I had the same problem last night, so I took the batterys out  and left it for a Day, have just put them back and its working for the moment, hope that it keeps on working !!! good luck with yours.
Posted on Feb 20, 2009
The Machine
  • 788 Answers
SOURCE: Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Posted on Mar 30, 2009
jimmyjimjam1
  • 66 Answers
SOURCE: Onkyo RC-588M
get a new remote control
Posted on Jun 29, 2009
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
How to reset RC-569M remote controller to factory defaults.
Not sure if it's the same, but for the Onkyo RC-799M controller the reset sequence is:
To reset the remote controller to its factory defaults,
while holding down RECEIVER, press and hold down
HOME until the remote indicator lights (about 3
seconds). Within 30 seconds, press RECEIVER
again.
Jan 05, 2015 | Onkyo Audio Players & Recorders
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
Onkyo RC-738M remote control mute does not work and volume control is intermittent. How to fix?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
If the remote control is found OK; check it with set it up to an other set-up code said for your TV. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 05, 2014 | Onkyo Televison & Video
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
My remote has a long delay on the up and down volume.it just started a few weeks ago and im getting annoyed..Common problem?
Manually turn the volume knob on the receiver several times as to loosen it up. Change the batteries.
Feb 25, 2011 | Onkyo RC-375DV Remote Control
The Vol button on my Onkyo RC-588M remote doesn't work
It probably can be fixed. Dirt and such gets on the contact pads...take it apart by carefully unscrewing it and remove the top half with the buttons facing you. You will likely see that the buttons are made of molded sheet of silicone, lift that off. Beneath where the mold was for the volume control you will see the actual buttons that control the volume, inspect it to see if it simply got pressed down too far and try to operate it that way and clean anything that needs it while you have it open. If it works without the silicone button cover panel on it, then you can take a small peice of paper wad and tuck it into the mold for the volume button so that when you press on it, it always makes contact.
Dec 14, 2009 | Onkyo TX-SR702 Receiver
All remotes controlling my Onkyo TX-SR304 stopped working
try putting the remote an inch away from the IR receiver on the unit and see if it works then, if so then you definitely know its broken. This can and does happen. From what you have posted it sounds like no remote is working on the receiver, the ir receiver can break. If you need further assistance let me know.
Thank you,
Lee
May 28, 2009 | Onkyo TX-SR875 Receiver
I have the Onkyo 706 with remote RC-717M. My remote just suddenly started to malfunction. The volume up is turning it down and vice versa. The power button to shut the receiver off is doing the function...
Have you tried resetting the remote? According to the manual (page 101), press and hold the RECEIVER button, press the AUDIO button, wait approx 3 sec. until RECEIVER highlights and finally press RECEIVER again. Of course if you've programmed a remote control code for your PVR in the RC-717M, you'll have to do it again.
Oct 18, 2008 | Onkyo Audio Players & Recorders
Televison & Video Logo
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
