Question about Vacuums
Hoover Model SH80520 won't start - Vacuums
Linx Hoover platinum won't turn on
more than likely you'll have to order a new handle. Those machines are built in pieces so you just cant replace switch, motor, etc....
Feb 13, 2013 | Hoover Platinum LiNX Cordless Stick Vacuum
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Model SH80520 starts and won't quit
that's how it's supposed to operate, switch on turns the unit on. switch off turns the unit off. thier is a wire that is connected to the leads on each outlet that turns the unit on when the hose is inserted and the switch is in the off position.
Mar 30, 2012 | Vacuums
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Oct 29, 2009 | Hoover Vacuums
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover model F8515 won' t **** up any water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=703954
Hoover Model F8515 won' t **** up any water
posted by kevingao92 on Jun 24, 2008
It could be in reverse do you have any tips
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Hoover Model # F8515 works on the pull back to pickup the water and on the push forward you can dispense extra water or solution and the brushes will still scrub but on the pull back it dispenses, scrubs and also picks up the water all in one sweep, if not then contact you local vacuum dealer in your area, check the owner’s manual for the trouble shooting guide and or call the Hoover Factory cust serv @ the information listed below.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover vacuum turned off and wont go back on
Generic problem for all Vacuums
Hoover vacuum turned off and won’t go back on
Not knowing the model number – or if it is a canister or upright --- you may have a defective switch and would need to replace it – check with you local vacuum cleaner dealer in your area or in the yellow pages or call the Hoover Co for further assistance
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 21, 2008 | Vacuums
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
