Question about Kenmore 500 6952 Dryer
Kenmore model 110.69522800
Drum rattles
Kenmore 65661 dryer rattle
Most likely it is your rollers. These are wheels that the drum glides on. Over time they wear out due to the heat in the dryer and the weight of the clothes
Aug 24, 2012 | Kenmore Dryers
My dryer is an old model kenmore, model # 76692600, that has started making a terrible rattle when the dryer is running. How do I get the top off odf the dryer so I can inspect the drum motor?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 05, 2011 | Kenmore Dryers
Found a large gray felt ring dryer - now it rattles
reattached the felt ring correctly around the drum to make it run quite again
Apr 26, 2010 | Kenmore HE5
Kenmore 80 Series loud rattling noise
Its called a Drum Support. Purchase at any appliance parts supply store or online from Sears or Whirlpool.
Part# 3397588 or 349241T (Pk of 2)
Jun 08, 2009 | Kenmore 63942 Dryer
Kenmore dryer making rattling noise
If the panel's clamps are broken it will rattle,for a quick fix i would use duck tape on both sides.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 16, 2009 | Kenmore 63942 Dryer
Kenmore Dryer makes Noise Model 86671100
Very few of the tubs are true to round. You stated it has made the sound since you've owned it. Observe and listen to see if you can determine the closet area to the noise. Usually moveable parts get louder over time. Your problem could be a number of things. I would start by adjusting the bottom leveling feet and be sure it is level front to back as well as left to right. Other items could be drum seal gasket bearing, rear felt seal, rear drum support roller, belt tension pulley, blower wheel, blower wheel housing, front drum glide bearing, shaft drum support roller, bracket for drum support roller, front ring bearing kit, pully on the motor, or even lose cabinet housing bolts.
Use the below link to refer to on how to get inside:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 07, 2008 | Kenmore 22422 Top Load Washer
Rattling
Level the drier, check the drum for foreing objects, check your belt and replace if need to. Check your rear drum seal, and your drier idler pulley, and replace if need to.
Jul 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
Noisy Gas Dryer
possible problems are 1.) drum rollers are bad. These support the back of the drum and allow it to roll freely. 2.) Tension pulley that keeps tension on the belt could be bad. This shouldn't be a difficult problem to diagnose or an expensive one to fix if you do it yourself.
Oct 11, 2007 | Dryers
Kenmore 500 6952 Dryer Logo
16 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
