Question about Apple iPod nano
On-The-Go has stopped working....
I got it to work at first -- but it has been monthes since it would add songs to the on-the-go playlist.....
i think i caused the problem --- I renamed the old on-the-go.....  even though there are like 3 now ---- none of them will add new songs....
  • fiarucci Apr 15, 2008
    Somewhere or other I browsed up a comment that made me understand the problem..... It is the way the Software works!
    --- ipod doesn't let you add to on-the-go while you are just playing the music..... you have to go up a level to either the playlist or the library and then browse to the darn song.... it still works, I just had to go to the right 'layer' in the machine --- it doesn't work that way it would be convienent -- but it does work... doh!
  • 3 Answers
Try deleting all three aside from one, and keep it named the original. If that doesnt work, you could try restoring factory settings. that would probably work best. I dont think will delete your music library, and you could probably just create separate playlists if you want other "on the gos" :)
Posted on Apr 11, 2008
SOURCE:
Hii.. i recently buy lava a10 but i m unable to add songs from my memory card to the audio player's plat list. tell me how can i do that?
Menu-Audio player--Playlists-Create playlist--Now create playlist as you want-Now select same playlist which you have created-Options-Add-Now if you want to add single song, please click on song name and song will be added-if you want to add multiple song, then select "Multi" option from left side of the bottom-Mark the multi songs -Now press "Done" from left side of the bottom-Now select the first option of "Play" to play songs of playlist.
Mayank Purohit
Jul 25, 2011 | Cell Phones
I can't make my archos
be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
let me know
Aug 29, 2008 | Archos Audio Players & Recorders
IPod classic stopped shuffling this weekend. I've had it for several months and it's worked just fine, but all of the sudden it stopped shuffling songs within playlists that were set to shuffle. ...
Hey press the play pause button and the enter button at the same time if it has a lock move it baca and forte 6 times while holding play pause button and enter/centered button for 6 seconds, that should solve from freezing ipods to non functioning well :)
Jul 20, 2011 | Apple iPod touch
How do you add songs to a playlist on the ZEN Mozaic?
Don't really know, but this works
Browse music library adding tracks to 'add to selected'
go back tomusic lib and goto playlists
select the playlist you want, add to selected
save selected as playlist, give it the same name as the playlist youeant to add the tracks to andchoose overwritewhen prompted
I'm sure there is a quicker way way, but hey, it works
Mar 08, 2009 | Creative Labs Creative Technology Zen MP3...
Can't create playlists on my zen x fi
I tried some suggestions posted here, and after some testing, I can now give you step-by-step instructions to create a playlist on your Creative Zen.
First, you need to think of the NOW PLAYING list as the "selected songs to be added to a playlist".
So, to start clean, let's empty out the NOW PLAYING list as follows:
1) from the MUSIC menu, select NOW PLAYING
2) when a song is shown on-screen, click the context menu
3) select REMOVE ...
4) select REMOVE ALL
Now, the NOW PLAYING list is empty.
Now, you need to select (mark) the songs you want to add to your new playlist:
1) go to an individual song
2) click the context menu, and select ADD TO SELECTED
3) go to another desired song, and do step 2) again
4) repeat until done
Now, to create a NEW playlist, go to the MUSIC menu, then:
1) select NOW PLAYING
2) it will show you the first song that you selected
3) press the Right button, to scroll through all of the other songs you selected
4) when any song is shown on-screen, click the context menu
5) select SAVE AS PLAYLIST (this refers to ALL songs in your NOW PLAYING list)
6) type the name for your new playlist, and click checkmark
ALL of the songs in the NOW PLAYING list are now saved as your New playlist.
From the MUSIC menu, select PLAYLISTS. You will see the name of the playlist that you just created. When you select that playlist, you will see the list of songs you had selected.
Please note that these songs are still in your NOW PLAYING list also. To create a another New playlist, you will first need to empty out the NOW PLAYING list as you did above.
I hope that helps.
Enjoy!
Nov 30, 2008 | Creative Labs ZEN SLEEK MP3 Player
Sony NWZ-S616F playlist problem
to add files to walkman i open the walkman icon that appears when i connect to pc an find and open folder named songs....drag and drop your song files ( as mp3) and thats all
hope this helps
Sep 08, 2008 | Sony Walkman NWZ-S616F MP3 Player
Won't Process a Playlist
Had problem when on the expansion SD card not being able to add playlists, found out playlist are only saved in main memory, so I had to remove a song from main memory to add another playlist.
Aug 12, 2008 | Rio Cali Sport MP3 Player
Probelm with playlists
The Vista compatible software may work different, but I have mine set to Repeat OFF, and I have no problem with playlist play. Is it possible that the songs that you put on your playlist are in the wrong format? If they were streaming files, or DRM-encrypted WMA's, there may be issues with playback. Convert the songs in your playlists to mp3 format ON THE COMPUTER, and then delete the playlists that are not working OFF YOUR SANSA. And then re-add the playlists to your Sansa.
-Tha Mp3 Doctor
Jun 03, 2008 | SanDisk Sansa Clip MP3 Player
How do you add a playlist to the player!!!
There is another way but that is called Favorites. First go to settings on the player and enable advance then go to one of your songs and press the select button then it will give you an option that says add to favorites? choose the check mark to add that songs to your playlist. Also there is a way to add playlist using windows media player. The steps given would be for windows media player 10. First click on the Library Tab thecn click on the arrow for the Now Playing List choose New List then Playlist, now add songs to your newly created playlist by dragging them to the drag items here window after you have choosen all the songs you like click on Now Playing List and choose Save Playlist As.. After saving the playlist change the settings of the player to Autodetect and connect the player to the computer. Now wait for it to be detected by the computer and click on SYNC tab on the windows media player software. There are two windows the left is where you will choose the playlist the right your mp3 player. Choose the playlist that you have created and click on START SYNC now it will be transferring the playlist to your mp3 player just go to Music then Playlist. Hope this helps :D
Jun 30, 2007 | SanDisk Sansa m230 MP3 Player
Trouble Filing Songs into Playlists
ok, sounds like a problem I had when I was working out the software! The easiest way to create a playlist with the Zen, is doing it over your PC, if you don't have the software it is available for FREE download at the official creative Zen site, just choose your model and region then hit download- simple! (You won't need Zencast with sleek photo model) ok! install your software blah blah blah, once it's gone through that process, restart your pc and then plug in your zen. the software should instantly recognise that your player is connected, so now, you can open up the software via desktop shortcut or start menu. From here, you've got a whole ton of options, whether to add to your library, create playlists etc etc. Choose create playlist and the process is easy. Left side of the screen is navigation of your Library, right side is navigation of current playlists. Create a new list, then name it. From the top left of the screen, select a folder on your library to open, the lower left displays what's in the folder you are viewing. move tracks over accordingly, holding down ctrl while you click is a fast and easy way to select more than one track at a time. hit add in the center of the screen to move stuff over to your new list. when you're done, save it. when you exit the software and unplug your zen, it should take a minute to update itself, sometimes you may need to restart Zen also to get the playlists updated. I hope this helps!
Apr 19, 2007 | Creative Labs ZEN SLEEK MP3 Player
Apple iPod nano Logo
37 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
