Question about Acer Office Equipment & Supplies
Canon f131700 copier will not print. just shows a "P" when i turn it on
4 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: canon copier NP 6412
It is a older copier, it could be a fan is not working, is it making noise. It may be failing......
Posted on Jul 23, 2008
  • 126 Answers
SOURCE: cannon copier
Where is the machine saying the jam is located? Does the paper even start to feed? Does the paper feed to the next feed area? If the machine sounds like it is feeding ( trying to feed) and the paper is still in the tray --- clean the feed roller/ tire with rubber restorer or a high alcohol base cleaner. IF the paper is fed part way out of the tray to the long ( most of the time) black reg. roller and now farther --- clean the reg. roller. There is always the chance that you have a bad feed motor or reg. motor. Also look to see if an actuator / switch has been pulled / knocked out of position. They is is small cradles and can be snapped back into place.
REG = registration
Posted on Jan 07, 2009
  • 122 Answers
SOURCE: i am using canon ir
there may be problem with primary charging roller. to replace the primary charging roller, take out the drum unit, remove plastic cover, remove three screws of the shaft plate, take out the drum,detach primary charging roller from stand and replace .
Posted on Feb 12, 2011
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
What is Error code 8-0 630?
my dear you chek heater unit and reast codes
in program
Jan 16, 2015 | Kyocera Copystar CS-1635 Copier
Will not print after ink replacementit shows
shut down computer
unplug printer from power outlet ( it must be unplugged )
remove both printer cartridges
make sure there is no tape or other items on cartage
reinstall cartridges
plug printer in
turn on printer
turn on computer
Feb 15, 2014 | Canon Office Equipment & Supplies
Print driver (2228C PCL 5C) shows printer queue offline. How can I bring it back online? I have rebooted the printer. There dosen't appear to be an option on the print queue when going in as admin on...
Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
May 12, 2011 | Ricoh Aficio 2228C Copier
SHARP AR-5320 is not printing. it is connected by USB. It is showing ready and when i give print command it shows that the document is printing and there is some action with the printer but the print...
remove driver from control panel,disconnect USB restart pc insert cd ,install again ,when pc wants to connect copier,do this and wait to complete.your cassete size must be same as your print size
Mar 05, 2010 | OCE 3140 Copier
My printer shows ayellow light - toner save-and prints faint
You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
Oct 30, 2009 | Nikon COOLPRINT Thermal Printer
Trying to print, but Status Paused is showing
Hi
Thanks for using FIxYa. Please turn the printer off and then cancel all the print queues pending in the bottom toolbar by double clicking on the printer logo if you want to delete all the pending printing files. Now turn the printer on. If you do not want to cancel all the printing jobs then you can double click on the printer logo showing in the right side of the bottom tool bar and then right click on the printing jobs pending for printings then click on restart printing. Issue will be resolved and it will not show ‘paused status’.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 04, 2009 | HP PSC 1210 All-In-One InkJet Printer
Prints are only at 80%
make sure your paper is not set to "ltr-r"or "letter r" which is the same size paper, just turned the other way. The control panel should show you the paper size its set for, or you can turn the original sideways if the platen/target glass allows for this size. This machine is a digital copier, so it should be able to turn it the proper direction unless its programmed for "ltr-r" copying.
May 26, 2009 | Sharp AR-164 Copier
The printer show me an eror and the number -1 (minus one)
What it is saying is that it had or has a paper jam. Did you look for a paper jam? Also, did you try to hit the reset botton & did you try turning the copier off & cancel your jobs in you printers Que?
Nov 09, 2008 | Sharp AR-M205 Copier
Call service
Shows ASIC error. Unplugg the copier, wait 30 seconds and turn it back on again. See if the error appears. Does this error code happen when you turn it on or when you print something to it?
Aug 02, 2008 | Sharp AR-275 Copier
41 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
