Question about GE Ericsson VintaSynthesized Portable Uhf Radios Comb P9rme Lot 2 R
How to program ge p9rme handheld radio
OK So how does one program these radios?
How do I program this unit? I recently got one and found a charger for it and now i would like to use it to listen to the county fire calls so i was wondering if anyone knew how to program this unit.Where...
You cannot program the radio. Find a GE dealer. Business band, not consumer band and must be programmed with software and cables specific to this model of radio. MPI's were a good handheld. Model number is more helpful than a serial number.
Jan 13, 2015 | GE Radio Communications
How do I program channels
The GP88 is a dealer programmable handheld radio. It requires Motorola proprietary software, programming cable and R.I.B. (radio interface box). You will need to inquire of your nearest radio dealer if they have the appropriate software.
Oct 22, 2014 | Radio Communications
Programming radios
You must use a compatible programming cable and software (such as Chirp) to program the radio, and the frequencies must be within the radio operating range [400 - 471 MHz].
Feb 26, 2014 | Baofeng BF-888 S UHF 400-470 MHz Portable...
Programming radio BaoFeng BF-888 S
This is a very broad question, however if you are just needing some instructions on how to program the Baofeng BF-888 I would start by Checking Google for an operators manual, However these radio's are much easier to program with software. Search Google for a software program called Chirp. I do believe it has support for your radio, and that will allow you to program your radio, for a more detailed tutorial, check youtube.
Portable radios
the BF888 is NOT a vhf radio, it is a UHF radio so it will NOT program VHF frequencies
Oct 02, 2013 | Baofeng BF-888 S UHF 400-470 MHz Portable...
Need radio frequency codes for Sacramento, and West Sacramento Ca for my bearcat
Most Ham Radio outlet stores sell current frequency lists--depending on type of scanner you have (trunking, digital etc) you may be able to program not to mention doing a search mode for the scanner.
May 04, 2012 | Uniden BC72XLT Handheld Scanner
I wanna be able to program my scanner where i would be able to listen to things going on in the neighborhood
HELLO THERE:
Just go to scanner live.com and it will bring you to a scanner web page that you can find your area ok ?
best regards
michael
Sep 14, 2009 | Radio Shack Pro-95 Handheld Scanner
Programing
I assumed that you mean Motorola GTX handheld radio. It can be programming to work with conventional, if it's a trunking radio then need to keep at least one trunking in radio, otherwise it lost all trunking.
radcom907
Mar 02, 2009 | Radio Communications
Won't scan
Check Batt, and adapter connections. Remove Batt's then try only adapter. if it works your ok. or the other way. remove electric and try batt. if it works yours ok. if all fails...buy new radio, Seriously.
their a dime a dozen these days. Oh might try turning on off knob real fast, could be dirt in the pot.
Oct 19, 2008 | Uniden BC60XLT-1 Handheld Scanner
GE Ericsson VintaSynthesized Portable Uhf Radios Comb P9rme Lot 2 R Logo
Top GE Radio Communications Experts
Greg Cann
Greg Cann
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
