Question about Hitachi 50V720 Television
Hitachi Rear Projection LCD TV Lamp
Ls it worth replacing lcd lamp every year or should l  buy a new TV ? It's a 50 in Hitachi LCD  Rear Projection TV
  • 1 more comment
  • Anonymous Nov 29, 2007
    well lets see, 159-200.00 or 1500.00 i think the lamps cheapest and its 5500 hrs mine got a yr and a half with alot of use, all hdtv lcds have lamps that need to be replaced
  • gibsons3 May 18, 2009
    i have a hitachi lcd rear projection tv and the lamp only lasted for a year, and the lamp replacement are too expensive, anyone have any advice on where i can find a cheap replacement lamp. thanks!
  • Anonymous Mar 23, 2014
    We unplugged and plugged back in and we still have no picture or sound
  • 579 Answers
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Posted on Dec 31, 2007
Hitachi LCD M50VS810 -- picture gradually darkened up over the past 4 days and now picture won't come on. Replace bulb?
If it uses a lamp that is possible---sets with a lamp will often dim down just before the lamp fails in a total way.
May 16, 2012 | Hitachi 50VS810 50" Rear Projection HDTV
I have a Sony Grand WEGA KDF-50WE655 50-Inch LCD Projection TV and when I turn it on the screen stays black and the green light flashes for 20-30sec then the TV turns itself off and 2 red solid lights...
The tv projection Lamp inside the tv now has it been inside this tv like 1 1/2 or 2 years already and tv is on and used it like 4 or 5 hours every days?Yes,the tv now the 2 red LEDS solid lights apear.One of those light have a word "Lamp" written on it bazel frame?Yes,100% ur tv projection Lamp life are over and ending.Tries websites like, to buy a new tv projection Lamp for the replacement.
Jul 18, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a sony xbr lcd projection tv . it goes on and off all the time . like every two min . and the standby light comes on. model KF-50XBR800
Its symptom of weak lamp that reaches to end of its working hours life span. If lamp has not been replaced in last 2-3 years then replace it to fix tv problem.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Jul 16, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
I have a question, We bought our Hatchi 50 inch tv 3 years ago
The manufacturer normally doesn't count the lamp for the warranty, but call them definitely worth checking w/ the manufacturer. Otherwise if you need to buy a lamp you can try they have FREE trouble shooting available so you can check to make sure it is the lamp.
Apr 21, 2010 | Hitachi 50UX57B 50" Rear Projection...
TV turns on but produces no visual or audio. Screen just stays black
Your lamp is burned out . I have a 52" hitachi lcd as well, and i have hadd to replace the lamp once a year. its a mercury based bulb which emulates alot of heat and if your exhaust fans are not working properly it will cuase it to fail or burn out more frequently than it should. cost is @ $120.00 for replacement bulb
Apr 12, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
Nov 08, 2008 | Hitachi 60V500 60" Rear Projection...
Depends on whether you use the TV as your "daily driver" or not. Colour patches on the edges of the screen sounds a bit like a purity problem. If replacing the lamp every year is proving too expensive, not to mention a tad repetitive since it indicates the short life of the lamp(s), plus the set happens to be a few years old, perhaps consider a new TV of approximately the same screen size (50" and up) - if the latter is what you want to do.
Dec 19, 2017 | Televison & Video
Hitachi 50V720 Television Logo
1,420 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
