Question about Xerox Office Equipment & Supplies
Code 127-211 come on my xerox 700 - Xerox Office Equipment & Supplies
How to resolve the error code 042-700 over heating in 6280 xerox col. printer
The MCU Board is overheating. If the room temperature is normal, replace the MCU Board.
http://www.iteminconline.com/622s01684_960k39348-960k39347-960k39346-960k39345-960k39344-960k39343-622s01684-xerox-6280-mcu-board-engine-control.htm
Nov 07, 2015 | Xerox Phaser Office Equipment & Supplies
Error code 078-240 for xerox 700
078-240 (HCF3.2) Tray 7 Lead Heater Fail 078-241
You will need Xerox tech help.
Sep 27, 2015 | Xerox Office Equipment & Supplies
I want to contact to canon xerox service centre kolkata
http://www.xerox.com/about-xerox/contact-us/enin.html
  • Contact Us - Xerox Find a local Office Products dealer in your area: Kolkotta Office Xerox India
    Limited 37, Shakespeare Sarani, 1st Floor, Kolkata - 700 071. Sales: 033 -
    44004875 ...
  • Copiers like the Xerox personal copiers offer functionality that takes into
    consideration ... 8/1, Lalbazar Street, Room No.1 D ,1st Floor, Kolkata - 700 001,
    India.
    http://www.copier.in/photocopiers/personal-copiers.html
Jan 25, 2012 | Canon imageCLASS Office Equipment &...
Error code 010-319 on xerox DP 700 ?
error code 010-319 replaced fuser still the same
Jan 01, 2012 | Xerox DocuColor 12 Color Copier
My Xerox Copy centre C123 shows error code 124-315 pls help
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Feb 11, 2010 | Xerox CopyCentre C123 Copier
A code 041-345 has appeared on the dc 700 and the code is not in the xerox manual. What does the code mean?
we had the same problem. fuse f2 on iot board was blown. fixed it buy soldering a new fuse
vikas
agra
india
Nov 05, 2009 | Xerox DocuColor 12 Color Copier
61 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
