Question about Dell Vostro 1000 Notebook
What makes the fan sound like its trying to start when powering on but stops very quickly
  • Dell Master
  • 9,587 Answers
It doesn't run at full speed until the processor has generated heat. It will speed up long enough for the excessive heat to dissipate then will run at a slower speed. If it stops completely it needs to be replaced.
Posted on Jan 15, 2016
Makes quick gurr gurr sound in tower. what is happening. computer is slow too
This sounds like a bad fan, could be a case fan, cpu or power supply so need to identify where its coming from by taking the side of the case off.
Mar 22, 2014 | Gateway GT5477E Desktop Computer - 1009589...
4 fans bought in April from Costco and pac tested. 1 makes a a funny sound when plugged and does not work.. Can this be brought to a centre to be repaired as a callout cost 55 pounds Many thanks Mrs...
It sounds like you bought these items online from Costco, unless you have a Costco close by. Using the term "pounds" tells me you are in England someplace. A repair shop should be able to repair the problem easily and quickly. The noise you hear might be from the motor that is trying to start. Did you try a different power supply to see if the problem is your power outlet? You might try that. Cheers.
Jul 16, 2011 | Honeywell Dryers
This heater will run for about 5 minutes or so and then the fan stops.if you use a screw driver and turn the fan really quick it will start working again.
Unfortunately it sounds as if you are loosing the fan motor, or it could possibly be in the fuel pump as it is run from the same motor.You could try cleaning out the fuel pump by taking it apart and cleaning it then make sure you pay attention to detail putting it together. It could be dirt in the pump but I lean more towards fan motor.
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
My gateway computer do not turn on.the fan try to start and stop.what should be happenning?
I think that the CPU fan isn't working as it should and the CPU is overheating quickly. If the CPU is heating too fast, the mainboard is automaticly shutting down the all PC to prevent damage. Your thermal paste might be gone. Isn't the computer giving any sounds or LED flashes ?
Nov 02, 2010 | Gateway 830GM power supply **FREE **...
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Desktop Fan "surges" in and out.
Chazzl,
Probably the desktop fan, a quick way to test for sure is to stop the fan with you finger when it is making the noise.
Just place your finger lightly in the middle of the fan and check if the noise stops.
Dont leave your finger there for more than a couple of seconds and mind the blades as it does smart a bit if you catch them.
Good luck
Nick
Oct 27, 2008 | Compaq Presario 5000 PC Desktop
Power steering problem
it is not the pump that stays on its the fan if your hearing a wizzing sound that starts off low and progresses high very quickly. this stops when u turn ur car back on and continues once off but leave it off for a little while and it should stop i believe its a fan because my friends cobalt does the same thing
Oct 08, 2008 | 2003 Mini Cooper
1 and 4 fan problem
This might happen when it detects a non-functioning fan (to preserve all other components).
We've had the same problem on one of our server, one fan wouldn't start (needed more current to start it)
We had to replace the motherboard on server to make it work, since this one got it power from the MB.
A temporarily fix was: Pop fan 4 out, give it a push so it rotated and quickly insert it before it stopped, hope it won't be stopping until you receive a new motherboard.
Sep 03, 2008 | HP Compaq ProLiant DL380 G3 Server
Sound comming from laptop
Sounds like a power supply fan problem - these can be easily and fairly cheaply replaced - it does not need much experience or skill to do this, but in order to purchase a new one you probably have to go to a repair shop anyway, so for a few bucks you can probably get them to replace it anyway. If you want to check it yourself, establish first of all if you can open the case, then listen to each fan individually (being careful not to touch anything at all inside) hopefully identifying which fan is the noisy one. If you feel competent to remove and replace this yourself then ensure the power is off and that you have adequately grounded yourself before touching anything inside, remove the offending fan and find a pc supplier who can get you a replacement. If you just want a quick fix - usually only lasts about a week - then some PTFE (teflon) spray can sometimes help noisy fans, but truly when they are on their way out they need replacing.
Feb 23, 2007 | HP Pavilion zd8000 Notebook
Dell Vostro 1000 Notebook Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
