Question about Canon ImageCLASS MF4370dn Laser All-in-One Printer
Canon can not communicate wth the scanner windows 8.1
CanoScan 8000F Installation for Windows 8.1
Unfortunately, the Canon 8000F is not compatible with Windows 8.1. You can find this at http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductViewerWithDefaultFilters?TempOsid=Windows%208.1&Locale=en-us&Architecture=X64&TextSearch=CanoScan%2B8000F&Type=Both&CurrentPage=0&TotalPages=1&ShowCriteria=0&SortCriteria=Relevance&Compatibility=Unknown&LastRequested=14. Canon choose not to write a Windows 8 or 8.1 driver for this scanner. The changes between Windows 7 and 8 mean that the old driver won't work. The compatibility mode doesn't help in this case.
You have two choices: The cheapest option (if you buy a used machine): You can get a second computer with Windows 7 or an older version of Windows installed that does support the Canon 8000F. Alternatively, with a computer with more than 4GB of memory and a CPU that supports can support a virtual OS to buy 1) an upgrade to Windows 8.1 Pro and 2) a Windows 7 license and DVD. (This will cost at around $200 for Windows 7 Home Premium and the upgrade.) Then you can add the Hyper V feature and install Windows 7 as a virtual OS with at least 2 GB of your memory assigned to virtual OS. Install the scanner in that virtual computer.
I hope this helps.
Mar 06, 2014 | Canon CanoScan 8000F Flatbed Scanner
I installed the new Canon LiDE 110 scanner drivers. When I click on the Scan button, it gives the error msg: Cannot Communicate with scanner. Cable may be disconnected. Scanner driver will be closed
I was getting that same error message, every second time I tried to scan something. I had the scanner connected to a USB 3.0 jack. I switched to USB 2.0 jack, and the problem was solved.
Oct 06, 2012 | Canon CanoScan LiDE100 Flatbed Scanner
Driver Canoscan N670U for windows 7 64-bit
Free option to use CanoScan N670U wth Windows 7 64 bit
VueScanner cost$ --> I am running Windows 7 64bit and was able to use my CanoScan N670U by Installing Windows XP Mode in Windows 7 at no additional cost
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
After install the software loaded and the only trick was to click the "USB" dropdown in the virtual machine menu at the top of the screen and select canoscan
Jan 16, 2012 | Canon CanoScan N670U Flatbed Scanner
Scanner won't communicate with computer
Try this,
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
Right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready toi use, re-connect the scanner USB lead.
Windows should re-install the drivers and tell you the scanner is ready to use................hopefully!
Mar 25, 2009 | Canon CanoScan 4400f MultiFunction Color...
Cannot communicate with scanner message
Try an get a USB 2.0 printer cable. Some of the Canon scanners will not communicate quick enough without one.
Nov 03, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MX700 Scanner Problem
I was having the same problem, and thanks to the person who posted solution number two which simply highlighted the fact that the apparently software that came with the Canon Pixma MX700 unit is not compatible with Window Vista.
The reason I was confused is because the printer was working perfectly fine across the network, but when I went to scan my computer would tell me that it can't communicate with the scanner. I'm thinking ... "well since you can communicate with the printer, you should be able to communicate with the scanner, after all, they're the same device!"
As a workaround, I used a third party program to do the scan (in this case, Photoshop) and everything worked fine. If you have Photoshop, just go to file > import to start the scan. If you don't have Photoshop, I would think whatever program you are using for image editing may have the same functionality.
Hope that helps,
Brian
Jun 09, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon ImageCLASS MF4370dn Laser All-in-One Printer Logo
196 people viewed this question
old marine
old marine
