Question about Minolta EP4000/5000 CS/PRO Copier
400 cod are coming
3 time lamp fuse
    President:
  • Minolta Master
  • 990 Answers
Hello sir; If you got 3 times fuse burn out , you better check the scanner fan is working ? or the air filter is floating the air.
Posted on May 18, 2009
What can i do if my photocopier is showing me c400
c 400 is the exposure lamp on the copiers is failing or has failed , change it
Nov 26, 2014 | Konica Minolta Cameras
Tv blinks green for a few seconds then u hear a exhaust sound and then the lamp light turns red and shuts down.
Check the high voltage circuit. The TV has a chip that checks all the circuits before allowing to turn on. My Samsung had only a high voltage of 380 votes DC at the capacitor. Samsung has 3 boards, inputs (control), video and power boards which has 120 volts enter leading to a fuse, then a small high voltage transformer, with a capacitor - 100 uf rated at 450 volts. Found two capacitors - 150 uf and 220 uf rated at only 400 volts and connected them in parallel and measured the voltage showing 391 volts. The TV worked again. Good lucky
Jan 11, 2018 | Panasonic PT-56LCZ70 56" HDTV
I need to fix now this cod c44 i know that is fusing problem but ao can i reboot the machine or reset this cod for copier toshiba studio e 205
v Switch off the printer first.
v Now Power the Printer by pressing 0 and 8 keys (keep pressing).
v Then a test mode comes up.
v Now Type 400.
v Press START (!)(You will get a counter and now you need to reset this).
v Type 0.
v Press Enter(start)
v Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
v Now switch off the printer and on it normally.
v You should see printer working normally
Jun 04, 2011 | Toshiba e-Studio 205 Copier
What will cause the 120amp fuse to blow in ls400
hi, this must be a dead short. if you connect a lamp and lamp holder with the battery and the other side of the fuse if the lamp is lit the short is still present. LEAVE THIS LAMP CONNECTED this testing can take a long time. you need to disconnect, seat motors, or any HEAVY CIRCUITS.ALTERNATOR TO CAR MAIN CABLE IGNITION SIDE. WHEN THE FAULT IS FOUND THE LAMP WILL DIM OR GO OUT. i am sorry that i cannot do any more. hope you sove this. gerry
Sep 10, 2010 | 1992 Lexus Ls 400
Sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
C44-Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range.
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Aug 28, 2010 | Toshiba e-Studio 205 Copier
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Acer pd726w projector beeps
I hate to echo this problem, but did either of you ever find the solution to beep code? Our church has had the projector for just two years and the lamp must have only about 400 hours on it.
Oct 20, 2008 | Office Equipment & Supplies
Showing c04 problem
no cods?
can you take lamp out ? check with aom meter .sould have coninuity
hope that help
Oct 08, 2008 | Minolta EP1083 CS/PRO Copier
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
