Question about Harman Kardon DVD-22 DVD Player
Harman kardon dvd 28 reset - Harman Kardon DVD-22 DVD Player
robotek
  • 1512 Answers
SOURCE: How to I reset my
Hi odysy
I got this from the manual page 43.
Resetting the Remote Memory
As you add components to your home-theater
system, occasionally you may wish to totally
reprogram the remote control without the confusion
of any commands, macros or ”Punch-
Through“ programming that you may have done.
To do this, it is possible to reset the remote to the
original factory defaults and command codes by
following these steps. Note, however, that once
the remote is reset, all commands or codes that
you have entered will be erased and will need to
be re-entered:
1. Press any of the Input Selector buttons 4
and the ”O“ button Hat the same time until
the Program/SPL Indicator 2begins to flash
amber.
2. Press the ”3“ button Hthree times.
3. The red LED under the Input Selector4
will go out and the Program/SPL Indicator
2will stop flashing and turn green.
4. The Program/SPL Indicator 2will remain
green until the remote is reset. Note that this may
take a while, depending on how many commands
are in the memory and need to be erased.
5. When the Program/SPL Indicator 2goes
out, the remote has been reset to the factory settings.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 29, 2008
Benimur
  • 6966 Answers
SOURCE: Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
naebarbat
  • 508 Answers
SOURCE: drivers for harman kardon en toshiba satellite P100
driver for Satellite P100-ST1071 here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1484723&rpn=PSPA0U&modelFilter=P100-ST1071&selCategory=3&selFamily=1073768663#
or try other model for P100-? from >downloads>model
Posted on Jun 05, 2009
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
How do i reset an harman kardon avr-310
There is no reset for it, If it doesn,t stay on something is wrong with it,End it has to be taken in for repair,
Nov 01, 2012 | Harman Kardon Audio Players & Recorders
Lost remote control
Try to buy an original remote control. It will be very difficult to match this device with a universal remote control. Contact the nearest authorised service center for harman Kardon.
May 29, 2012 | Harman Kardon DVD 21 DVD Player
I need to hook my dvd player to my harman kardon avr 210
Follow the DVD manual. What model?
Register and download the AVR210 manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-210-Receivers-manual/id/386bh148/t/2/
This unit supports just about any option.
Mar 07, 2011 | Harman Kardon AVR 210 Receiver
How to unlock my harman/kardon dvd player from region error
1) PRESS SET UP
2) ENTER 3,1,4,1,5,9,THEN 0 FOR MULTI REGION
Dec 19, 2010 | Harman Kardon DVD Player DVD-27
Hi dear. how can connect my dvd to hamman kardon
connect tv video in to kardon video out (tv audio in to kardon audio out) dvd audio and video out to kardio audio video in. and if you what to record also signal from tv. make a cable from tv audio / video out to kardon audio / video in.
Apr 06, 2010 | Harman Kardon AVR 135 Receiver
Hook-up
http://wzpo.ask.com/r?t=p&d=cap&s=fwpus&c=a&l=zr&o=sb&sv=0a300516&ip=29b28a2c&id=9C081BFE154A69ACB38D55982924AB2E&q=manual+of+harman+kardon+avr+120&p=1&qs=121&ac=29&g=33c8zcdlUuHiRw&en=te&io=0&ep=&eo=&b=alg&bc=&br=&tp=d&ec=10&pt=Harman%20Kardon%20AVR%20120%20Receiver%20Owner's%20Manual&ex=tsrc%3Dtxtx&url=&u=http://www.manualnguide.com/download/manual-guide/harman-kardon-avr-120-receiver-owners-manual.html. have a look in manual above from page 9.
Sep 06, 2008 | Harman Kardon AVR 120 Receiver
Harman Kardon DVD-22 DVD Player Logo
71 people viewed this question
Top Harman Kardon Televison & Video Experts
Electro Med Services...
hims Patel
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
