Question about Welding Tools
Simadre plasma cutter blows breakers as soon as you turn it on
I used my plasma cutter and everything worked fine the first day. The next day as soon as I turned the cutter on it blew not only the breaker it was on, it blew the main from the garage to the house. Any chance anyone knows where I should start or could the cutter be bad, or is it the tipo
  • 25 Answers
WTF is a "tipo" ? YES your machine is defective.
Posted on Dec 07, 2014
  • 4090 Answers
SOURCE: ESAB 550 plasma cutter will not shut off, I suspect a bad switch
unlikely, the switch poles are not making contact or a wire has come adrift from one of the swiutch poles.
Posted on Jun 23, 2009
  • 313 Answers
SOURCE: spectrum 2050 plasma cutter .
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Posted on Aug 02, 2010
  • 17 Answers
SOURCE: I have a chinese three in one welder/plasma cutter in Simadre brand. It will not start an arc. The o.c. light comes on after a small arc and stays on untill machine is turned off. I removed mosfets f
loose connection somewhere inbetween the pcb's or mosfit pcb must be not working 1 or2 diodes/mosfit not working
Posted on Apr 21, 2012
  • 1212 Answers
SOURCE: esab plasma cutter fault light comes on as soon as it is turned on
The cable or cutting head may be damaged. The power connections may be loose, an internal circuit breaker may have failed. If the cooling fan does not come on, check the wiring in the cabinet for damaged wires. Disconnect fan wires- noting where each connected and check to see if the fan burned out- if it did, replace the fan and it chould begin to work correctly. If the fan checks out okay- it will have 2 discrete sets of windings-one for the fan, the other to provide control voltage.Check that board with the rectifiers as a rectifier may have failed or there may be a fuse on the board.
If it were mine, I would check everything under the cabinet after it has been thoroughly blown clean.
Posted on Sep 27, 2012
  • 1212 Answers
SOURCE: simadre plasma cutter
Green yellow would be earth ground. Confirm it with a test meter.
Solid green and solid brown would attach to the 240 hots- no return white.
I have a simadre cut50D an I don't have the ground cable can I still use it?
No. Check here for the specifics of how plasma cutters work: http://home.howstuffworks.com/plasma-cutter4.htm Without a ground cable, you cannot complete a circuit, and the physical basis of how a plasma cutter works doesn't function.
Sep 13, 2014 | Welding Tools
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
Esab plasma cutter fault light comes on as soon as it is turned on
Sep 06, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
Jun 01, 2012 | Welding Tools
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Our 2050 plasma cutter will not start,we have electric to it,we had a employee change air supply at the time it was working great then when he changed air it had water in line what can we do to find out...
Clear the lines out let the plasma dry out for about 3 weeks then get more air an blow it out agen and try too use it or if you just bout it take it back if thears a warrenty thares all ways a 90 day warrenty on them and if your lucky a two year an make shure you have proof you bout it
Dec 16, 2009 | Miller SPECTRUM 2050 PLASMA CUTTER NR NEW...
No full arc
the spark that you see when you touch work peice is high frequency,recheck connections like good ground (tight and clean)on the unit and work peice.no ground no fire.
Jun 03, 2009 | Welding Tools
Not getting a spark when I pull the trigger
Try checking the front Panel and Internal fuses, as well as the thermal overload.
This could happen when you exceed the duty cycle.
eg: 20% Duty Cycle In a period of 10 Minutes, 2 minutes cutting, 8 minutes not.
Best of luck
May 02, 2009 | Welding Tools
Plasma Cutters support
In this process, an inert gas (in some units, compressed air) is blown at high speed out of a nozzle; at the same time an electrical arc is formed through that gas from the nozzle to the surface being cut, turning some of that gas to plasma. The plasma is sufficiently hot to melt the metal being cut and moves sufficiently fast to blow molten metal away from the
Aug 27, 2008 | MILLER 192049 SWIRL RING PLASMA CUTTER
Welding Tools Logo
1,115 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
