Question about Electrolux Ergospace Cannister Vacuum
Electrolux ergo space vacuum won't turn on - Electrolux Ergospace Cannister Vacuum
The blue light doesn't stay on. What do I do?
Hi Alec from VacuumSpot here. In Australia these are sold as the ergo rapido. The most likely culprit is the charger itself we sell loads of Electrolux Ergo Rapido Chargers basically the best bet is to measure the output of the charger to see if it is working properly (watch video) if it isnt then simply replace the charger. If it is then replace the vacuum handset - Electrolux have made the handsets real cheap so you dont have to do a repair on battery or motor.
Oct 26, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
How can I replace the rechargeable battery?
Hi There,
Officially Electrolux don't want to sell the batteries so they discount the price of the hand held unit. Here in Australia they are called ergo rapido but it will be the smae everywhere I would assume. They will sell the battery on its own but it is more expensive than replacing the hand held part (without the filters) .
Jun 12, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
My back wheel won't roll on my electrolux 2100. If I turn the cannister over, I can spin the wheel, but when I place it right side down, it just drags on the floor. How do I replace it?
Hi you need to find a local Vacuum repair place one that deals in Electrolux, and go there and take the vacuum or the make and model, and ask for a replacement part, that is the only way that you would be able to obtain spare parts, in fact while you are there, perhaps even inquire as to how much it may cost to do it? ask for a "Quote" and go from there.
Oct 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
I am trying to disassemble a electrolux 2100. I have looked at instructions given by Chemist 1961 and others. On the side, I have removed the rubber covers over the plastic rails but I can't remove the...
There's a tab at the back of the rail that needs to be released. Turn the vacuum on it's side, slip the tip of a standard screwdrive into the space between the rail and the back of the vacuum, and tap lightly with a hammer. Tap toward the front of the vacuum a few times until the rail is far enough forward to be slid out fairly easily. As a side note, the rubber covers do not need to be removed to do this.
May 08, 2011 | Electrolux Lux 5500 Canister Vacuum
I am trying to find the user guide for my electrolux floor shampooer model 1522
You can find the manual at the following site. Click on the space beneath "older models", then on Lux Floor Pro, then on "download". This will provide you with a pdf manual on your computer that you can print if you desire.
http://www.aerusvacuums.com/support/manuals/
Mar 18, 2011 | Electrolux Floor Pro Vacuum
How do i use the electrolux z85 i have no manual
Go to Aerus site and download the manual. Click below and go to "Current Models". Click on the space and find "Centralux" Click "download". You will then have the user's manual in PDF format in the location you saved it.
Apr 01, 2010 | Electrolux Centralux Vacuum
Pronto doesn't work at all
Hi there SmartAlec from NelsonVacuums.com.au here. I assume you are not from Australia as that machine is called an ergo rapido here. That machine here suffers from very dodgy switches but little else goes wrong. I would suggest it is a repair for a professional to replace the switch. If it is under 2 years old it should be a warranty repair. Hope this helps.
Happy Vacuuming! :)
Aug 26, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Nov 04, 2007 | Electrolux EL7055A Bagless Canister Vacuum
Electrolux Ergospace Cannister Vacuum Logo
108 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
