Question about Jugs M6000 Lite Flite Rechargeable Battery Pack - A0050
CAN AOO50 BATTERY PACK BE USED WITH PS50 PITCHING MACHINE
Melting wheels on Casey pitching machine
First thing is to be sure the wheels are oem. Second would be to attempt to shade it or paint the rims on the wheel silver to reflect the heat. If is most likely the glue used on the rims is a heat set adhesive and melts at about 140 F
Jun 19, 2016 | Cars & Trucks
How to change direction of pitching arm on machine?
Have you contacted Iron Mike yet. Most small a/c motors only go in one direction. Need more info. Was it was working correctly, then changed? Or did you buy it used this way? If the machine is NOT turned off in the correct position, then restarted quickly, it will run backwards and jam up the chain. You may need a new motor. email me if needed, Steve Manookian Pitching machine repair, Los Angeles area, stevemanook@gmail.com
Nov 26, 2015 | Iron Mike MP-5 Pitching Machine
How do I adjust Iron Mike pitching machine? Throwing too high, lobbing the ball?
Sounds like many small problems. Have you contacted Iron Mike yet. Need more info. Was it was working correctly, then changed? Or did you buy it used this way?
Jun 23, 2015 | Iron Mike Baseball & Softball
How do I change the direction that the arm travels on an Iron Mike Machine?
Iron Mike Pitching machines can be configured for baseball, fast pitch & slow pitch softball.
Aug 30, 2014 | Iron Mike MP-5 Pitching Machine
Need wiring diagram for Iron Mike pitching machine
Contact Master Pitching Machine at 800-878-8228 and request an owner's manual to be emailed to you.
Dec 16, 2013 | Iron Mike MP-5 Pitching Machine
Fix jugs pitching machine wheel
What's wrong with it need more info
Mar 31, 2012 | Jugs Small Ball Pitching Machine
My jugs pitching machine is making a rattling noice in the motor area
It could possibly be one of the bearings starting to go, is the machine well used or new?
Oct 27, 2010 | Jugs Small Ball Pitching Machine
Jugs M6000 Lite Flite Rechargeable Battery Pack - A0050 Logo
203 people viewed this question
Top Jugs Baseball & Softball Experts
Ned Halaweh
Ned Halaweh
NOEL
NOEL
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
