Question about Bose Cinemate 1 Sr Speaker System
1sr no sound from optical audio
Tried 2 sources and tried to both the tv input and the Aux inputs but nothing in either case. The audioIQ does work for calibration.
SOURCE: Apple TV and Bose Home Theater
I had the same problem.
I could not get HDMI to HDMI to work.
i fixed it (work around), by connecting ATV HDMI to DVD HDMI port on V30, i then connect L&R to AUX.  I set the Bose remote for controlling ATV to AUX.
so to use ATV with Bose remote i know press DVD, this gives me the correct display but not audio, i then press AUX and this gives me ATV control and audio.
interesting, when i first set this up (trial and error), it didn't work.  I was doing some cable management clean up, when i got a fright and the thing started working...but i have a ghost in my house so that is probably a more plausible reason why its working now.
it feels like this product is only 90% finished
Posted on May 26, 2009
MarineTech1
  • 76 Answers
SOURCE: No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Posted on Aug 22, 2009
leethedeuce
  • 4472 Answers
SOURCE: I have an OLD bose lifestyle 25 (bought in 1999)
Hi there are different video selector boxes you can buy. here is an example:
http://www.thetwistergroup.com/store/customer/product.php?productid=40324%20X18195&source=fr
Eventually your going to have to consider upgrading home theater systems new systems have hdmi and hdmi upconversion so that you can plug everything into the stereo and then have one hdmi output going to the tv. is the rca connector the digital coax? you can usually tell by the color. this may be what you will want to use for audio. It really does get kind of complex.You may just not have enough inputs for everything. You definitely are limiting your hdmi use.
Hope this helps. If you have more questions let me know.
Thanks,
Lee
Posted on Sep 10, 2009
Testimonial: "all of the rca hookups are red/white....thanks for the help"
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
SOURCE: hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one: http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
Posted on May 31, 2010
Why can't I get picture or sound when my Sound Bar, TV and Blu-ray player are connected?
You have to run an audio cable from the TV to the sounder and put the sounder on the TV input for sound to work. The first choice audio cable for best sound would be optical cable if your tv has optical output on it. If it does then you would put the sounder on the din input for sound when watching antenna or any hdmi source connected directly to tv. If your TV only as analog rca out or mini audio out then put sounder on aux input. I think your sounder came with mini to mini stereo cable. If your TV doesn't have mini audio out the get a optical cable or you can find a mini to rca red/white will work. Optical is your BEST connection and soundbar would stay on din all the time for best sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Feb 10, 2015 | Vizio S5430W-C2 54-Inch 3.0 Soundbar Black
I just bought a samsung home theater in a box system, model Ht-D5500. And i also have a hd cable box. i was wondering how can i connect my cable box up so that i get audio from the speakers instead of the...
There are two ways of connecting to get cable TV audio from your Home Theater System.
1) If your HD cable box has a digital audio out ( either optical or coaxial ) you can connect this to the Samsung Home Theater Systems digital input. While watching a TV channel scroll through the Samsungs input ( source ) selector till you hear the sound. Remember to mute the TV sound while you are doing this.Most probably it will be the CBL/SAT input or Video AUX.
2) If your HD box does not have digital audio out you can connect the Red & White audio out of the same to your Samsungs Aux or TV or Video audio inputs . Ignore the yellow socket and connect only the Red and White audio inputs.For getting Video through the TV connect the HD box to TV via HDMI cable or connect the Yellow video out to the TV's Yellow video in. I am sure it is already connected .
Mar 21, 2011 | Audio Players & Recorders
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
How to connect my audio system directly to sony bravia
There is usually three ways to connect a TV to a Surround Sound system:
1. Optical Audio Cable (Fiber Optic)
2. Coaxial Audio Cable (Orange)
3. Composite Audio Cables (Left - White, Right - Red)
Once you select a cable to use that is compatible with both devices, you must then connect it to the output on the TV set, and one of the inputs on the Surround Sound Receiver (preferably the Video Input or whatever type you selected to use). Then you must change the input on the Receiver to the proper input that you connected the cable to (most Receivers will have a Source Button if not individual source buttons i.e. Tuner, Tape, CD, Video, Aux, etc.).
Note: Some Receivers if using a certain type of input will not have sound out of all 5 speakers unless the input is 5.1 compatible.
Jul 02, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Kenwood vr-7080
Is your tv wired to a cable box or an HD antenna?
Case 1: If your signal is weak, then the chances are that the feedback from your tv to the receiver's processor cannot interpret a Dolby Digital signal.
Case 2: Check the TV MENU AUDIO setting. Does your TV have a ON/OFF feature for the optical output, or any aux. speaker outputs?
Aug 04, 2008 | Kenwood VR-7080 Receiver
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Bose Cinemate 1 Sr Speaker System Logo
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
