Question about Foxconn Computers & Internet
My system turns on but the monitor shows a black screen and my mouse does not react what may be the problem? Many Thanks!
    President:
  • 2,992 Answers
Your system may be powering on, but it's not starting up. This might be due to the power supply, memory or system board. Start by making sure your memory modules are firmly seated and latched into their sockets. Then substitute a known good power supply to make sure that's not the issue. Finally suspect the mother board. A system that doesn't start is a common problem when the board is bad.
Posted on May 18, 2009
Screen not working
Does it seem like the laptop booted up all the way except the screen is black? Do you hear fans running, hard drive spinning? If so try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 29, 2012 | Computers & Internet
The monitor is a samsung syncmaster 920MW. It works when I turn it on, but then after three seconds it cuts off. The power indicator LED is still green. However the display is blank (as if the monitor were...
this is usually a short that reacts to heat. as it runs and warms up it shorts, then it cools, etc, etc. I would just replace the monitor. With the black friday deals you should be able to get a flat screen for under a hundred dollars.
best of luck
Nov 24, 2010 | Samsung Computers & Internet
When Window Media Center start up, i get post, then XP Splash Screen, the mouse appears with a black screen. I started recovery to recover to factory default, it seemed to work fine for a week or so, then...
You have PC problem nto monitor problem since you can see the mouse.
Try booting in safe mode (hit F8) while booting up then go to system restore and set it back to the date you remember before the problem started.
Did you installed any new software or updates before this problem started?
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2010 | Gateway 19" Flat Panel LCD Monitor
Toshiba m700 turns on but shows black screen and mouse only
Some Windows start up file is corrupted. Repairing the Operating System will solve the problem.
Jun 09, 2009 | Toshiba Portege M700-S7044X Notebook
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
Screen shows no signal
Hold down the power button for about 6 seconds continuously, this should wake it.
Sep 19, 2008 | Compaq Presario 5000 PC Desktop
Acer al1711 shows only a white screen
These are pretty old now but I'll respond anyhow-
When there is absolutely no screen content and white, it means that ALL pixels are turned off; black, means all are turned on. If you have a white screen, it means that a component in the video stream has failed; a black screen (preferable failure!) often means that the backlight lamp or its inverter have failed. The latter is a potential DIY fix, a dead IC in the video path normally not since most of the signal chips (ICs) are placed and soldered by robots and the pin spacing on those is pretty much beyond the capabilites of an untrained hand.
The only exception I can think of is if the ICs no longer have voltage supplied to them from the main power supply but you would need at least a cheap multimeter to locate that.
May 31, 2008 | Acer AL1711 17" LCD Monitor
Monitor not receiving data from computer?
If you did not hear any beep from your CPU, then the problem is in the system not the screen.
Try connecting the screen to another computer and try also a working screen of a friend to your computer...
You'll find out that either the screen or the computer...
Good luck... post me back for your result.
Don't forget to rate too.
Thanks...
Jan 29, 2008 | Dell E176FP 17" LCD Monitor
Computers & Internet Logo
104 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
