Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
How do you remove the trim ring from my whirpool duet dryer
Trim ring around opening and control panel has come loose the clips seem to have separated ffrom the ring and are still attached to the dryer front and I am not sure how to reattach?
2 Suggested Answers
vostendorp
  • 347 Answers
SOURCE: MDL WED9600TAO WHIRLPOOL DUET STEAM - THE TEARDROW
This was a very poor design from the factory ..The clips attach to the trim ring at the factory by plastic welding (MELTING) them in place to the stanchion's, in working on many of these sometimes you can super glue them back in place, but you will have to remove the trim ring completely to do it. other times i had to just replace the entire ring as it was to far gone to repair Just a bad design guess they didn't think it would ever have to be taken apart
Posted on Nov 17, 2010
Best (Broan) K260A - I tried to change the bulb as well....completely inaccessible to change with hands (bulb is set deeper in hood, not even flush) tried gloves, rubber jar opener but cannot get access to...
The lamp holder assembly snaps into a hole in the range hood with spring clips. To remove the light bulbs, you simply push and turn, like older, bayonet style automotive turn signal bulbs. It seems you have broken your lamp holder assembly. Just break the trim ring so it can be removed, or you can try to take it out reverse polish style by releasing the spring clips from the middle inwards. Once the trim ring is loose, you can extract the body of the lamp holder through the hole... the wires will be barely long enough to stick out the hole if you are lucky. If you are crafty, you may fashion a repair on the separated lamp socket assembly. If not, your replacement part number is SV16569. just call nutone-broan at 800-558-1711 and they will be glad to ship you a new lamp shell socket trim assembly.
25439092-xipalmoknr3fbjmp51kycajc-3-0.jpg Retail on that part is around $50.
http://cdn.appliancepartspros.com/images/product/cache/broan-light-fixture-assy-sv16569-ap5178165_01_l.jpg
Feb 16, 2015 | Cars & Trucks
Whirlpool duet dryer ring around the door keeps u hinging. They are metal and what I've tried is pushing them back in.
The clips are first secured to the ring. Then, the clips themselves go into holes around the door.
They are somewhat spring loaded and you'll need to compress the fingers on the clips to remove them from the holes. Then, position the clips properly on the ring and push the slotted section (on the clips) onto the plastic tabs around the inside of the ring. Then, use a soldering iron to melt the tab heads so the the clips will stay on the ring. Then, just line up the holes on the dryer with the clips and start pushing them back into the holes.
Remember, make sure the clips are aligned properly, else they won't line up with the holes.
Dec 29, 2014 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Why is my duet whirpool washer door not cycling through. It seems locked open
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism. I found this at the Appliance Guru website.
Jul 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How do i remove front panel on a Whirlpool wfw96heac
I have a whirpool duet qnd to get the front panel off you have to take out the soap drawer and there is a bolt there that has to come out.
also I had to pry off the trim piece around the control panel to get to the rest of the bolts. I did it carefully and it came off without breaking.
May 03, 2014 | Whirlpool WFW96HEAC R 4.3 cu. ft. Duet...
How do i remove the rear door panel on a 2005 pontiac grand prix
  • Instructions
      • 1Roll the door window all the way up. Disconnect the car battery's negative cable with a wrench.
      • 2. Remove all cover plugs on the interior door panel with a putty knife. Remove all armrests, door pulls, the window crank and trim-panel retaining screws with a screwdriver.3. Remove and disconnect any electrical devices in the door panel. Pry the controls out with a putty knife, and unplug the wires.
  • 4. Pry the trim-panel clips loose with the putty knife. Do not pry on the panel between the clips, or the panel could be damaged. Separate the trim panel from the door slightly, and disconnect the courtesy light. Remove the panel from the door.
  • Sep 12, 2012 | 2005 Pontiac Grand Prix
    I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
    Answer
    FRONT DOOR TRIM PANEL
    REMOVAL
    Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
    Disconnect wire connector from courtesy lamp.
    If equipped, remove screws attaching door assist handle to inner door panel.
    If equipped, remove screw attaching door pull cup to inner door panel.
    If equipped, remove screws attaching trim panel to door from below map pocket.
    If equipped, remove window crank.
    Using a trim stick, remove screw cover from switch panel.
    Remove screws attaching switch panel to door trim.
    Remove power accessary switch from door trim Front Door Switch Panel
    Disconnect power switch from wire connector.
    If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
    If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
    Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
    Lift trim panel upward to disengage flange from inner belt molding at top of door.
    Tilt top of trim panel away from door to gain access to latch linkage.
    Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
    Separate linkage rod from latch handle.
    Remove front door trim panel from vehicle.
    INSTALLATION
    Hold top of trim panel away from door to gain access to latch linkage.
    Place linkage rod in position on latch handle.
    Engage clip to hold linkage rod to inside latch release handle.
    Place front door trim panel in position on door.
    Install trim panel into inner belt molding at top of door.
    Install clips to attach door trim to door frame around perimeter of panel.
    If equipped, install screw to attach door trim to door panel behind inside latch release handle.
    If equipped, connect power switch into wire connector.
    Place power accessary switch in position on door trim.
    Connect wire connector into memory seat/mirror switch and install switch into trim panel.
    Install screws to attach accessary switch panel to door trim.
    Install screw cover into switch panel.
    If equipped, install window crank.
    If equipped, install screws to attach trim panel to door inside map pocket.
    If equipped, install screw to attach door pull cup to inner door panel.
    If equipped, install screws to attach door assist handle to inner door panel.
    Connect wire connector into courtesy lamp.
    Install lamp in door trim.
    Feb 02, 2012 | 2000 Dodge Caravan
    Remove stock cd player from 06 ford f150
    1. Remove the center trim panel around the radio and HVAC controls.
    Open the ash tray and pull on each corner of the trim panel. The 1st time you do this, it will be very hard to release the spring clips. Only need to pull out about 3/4"
    2. Once both lower corner spring clips are pulled out, work you way up each side, there are 3 spring clips on each side of the trim panel. Be careful with the top, the wires to the Passenger Airbag Deactivation indicator are very small.
    After the panel is puled loose, release the connector to the PAD indicator at the top, and undo the connector to the cigar lighter ( and park aid / traction control buttons if applicable ) and release the cam over connectors on the HVAC panel.
    Once you get to this point the radio is held in with 4 hex head screws
    Cigar lighter & HVAC connectors
    Spring clip locations circled in red
    Mar 24, 2011 | 2006 Ford F-150
    F 01 error code whirlpool duet dryer. Can I replace the control panel?
    Where is the thermistor on the dryer on whirpool duet or remove control panel
    Feb 28, 2011 | Whirlpool Dryers
    MDL WED9600TAO WHIRLPOOL DUET STEAM - THE TEARDROW TRIM\r\nAROUND THE DOOR AND UP INTO THE CONTROLS IS LOOSE AND HAS THREE SMALL "CLIPS (?)" STICING OUT BUT I CAN'T SEE HOW TO REATTACH THE CLIPS...
    Nov 15, 2010 | Whirlpool Dryers
    How to remove passenger side door panel, for 2000 Olds Intrigue?
    1. Remove the door latch trim plate (coupe and sedan front doors).
    2. Remove the ashtray (sedan rear doors).
    3. Remove the seat belt retractor cover (coupe and sedan front doors). Use a suitable door trim panel removal tool to release the clip retainers
    4. Remove the door lock trim plate and the power window switch, if so equipped.
    5. Remove the window regulator handle by removing the inner retaining clip, if so equipped.
    6. Remove the remote mirror control, if so equipped
    7. Remove the trim panel retaining screws
    8. Remove the door trim panel using a door trim panel removing to work loose the retainer clips.
    9. Detach all electrical and remote mirror controls, as required.
    To install:
    10. Install the wiring harnesses through the openings in the panel, as equipped.
    11. Position the trim panel to the door and align the clips. Press the trim panel to the door until all the clips are fully engaged. Align all the holes before engaging the clips.
    12. Install the screws, remote mirror control and inside door handle bezel, as equipped.
    13. Install the window regulator handle or power window switch.
    14. Install the door trim plate, seat belt retractor cover or ashtray.
    Dec 04, 2017 | 2000 Oldsmobile Intrigue
    Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
