Question about Hayward Sand Filter System & Tank 21" 1 1/2 Hp
In-g pool loss of pressure and bubbles from return line any ideas
I have an inground pool with a hayward super pump 1.5 hp and a hayward filter. when i opened the pool everything worked properly now i have a loss of pressure and little bubbles are coming out of the return into the pool. any ideas?
    Scholar:
  • 34 Answers
If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring. Once you remove the strainer o-ring make sure you lube it with a good silcone based lube.
Posted on Aug 15, 2009
No pressure in the filter
Pull the pump apart, maybe the impeller is broken, put a hose up the suction line to check for blockage, is there a non return valve in the suction line? Maybe just an air leak, only takes a pin hole !
Jul 15, 2013 | Pool & Spa
My pump is 3 years old. I replaced the shaft seal assembly and now the motor is making a strange sound (much quieter than normal) and shutting off every minute or so. There is no pressure on the filter and...
Sounds like the motor is not turning. Check your impeller and motor to see if it spins freely by hand.
If not then you either have something stuck in the pump or the bearings are bad. If it is freely spinning, check your start capacitor
Apr 16, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Pressure gauge at maximum
Do you have a 'Earth' (dirt) filter system.
If - yes - these get block v-quickly (v-quickly!)
* Try to minamize 'vac'ing your pool, (or clean filter each time after 'vac'ing Or Vac on waste setting)
* Use pool skimmer box filter socks.
Jun 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
New 1.5 hp super pump hayward, blows circuit when turned on...
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Jun 11, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward 1 hp super Pump just hums then shuts off.This is an inground pool
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
Jun 07, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Loses suction after 2 hours
Filters are getting blocked.
Clean more offten - use filter socks (if have skimmer box).
OR get better pump/filter system.
May 31, 2009 | Hayward 1HP Super Pump II Inground Pool...
Inground pool question. How far away can I position my skimmer.
you don't say the volume of the pool, but if the 1.5 was working before and you are not adding too many turns, it will work.
David
Apr 28, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward Sand Filter System & Tank 21" 1 1/2 Hp Logo
558 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Are you a Hayward Garden Expert? Answer questions, earn points and help others
