Question about Sony DVP-FX820 DVD Player
How to Factory reset
No picture
I want to change the language to English and the picture is to big for the screen how can i change the Hight and With of the picture Dynex Tv Model #DX40L260A12
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 12, 2017 | Dynex Televison & Video
Samsung LCD TV LE40R8 - Hard Reset
How do I reset the picture on my LCD TV to the factory settings?
The P.Mode button on the remote of your LCD TV lets you cycle through four factory preset picture modes: Dynamic, Standard, Movie, and Custom. To return the picture on your TV to the original factory preset, press the P.Mode button on your remote until the TV displays the Standard mode.
Nov 14, 2007 | Televison & Video
I have sound and no picture on some stations and others have picture and no sound
Do a factory reset to this set, and then check. After reset, you have to re-tune the set [auto-tuning].
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 11, 2017 | Televison & Video
Tv picture is zoomed in. How do I reset the picture size to original setting without the original remote control?
Do a factory reset. There are two methods to reset TVs. Hard reset and factory reset. To make it a hard reset unplug the set from the AC mains wall socket and reinsert after an hour or so. To make a factory reset you have to enter it's service mode option. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
Feb 04, 2017 | Televison & Video
Television froze but when turned back on, the 1080i 60 Hz is flashing in the corner, no picture or sound
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 19, 2016 | Proscan Televison & Video
How can I reset only the picture settings?
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 10, 2016 | Televison & Video
Cannot display picture on a fullscreen
Check the aspect ratio setting to picture. Get into its picture setting menu, and try to adjust it there. If it do not help you, do a hard reset, and then a factory reset, if needy.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 01, 2014 | Televison & Video
How can I fix a tv that has been reset to factory reset
Try resetting it again, resetting it should bring it back to the way you received it from the store. Unplug it first, then plug it back in, then try the factory reset.
Jun 08, 2014 | Audio Players & Recorders
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
How do I do a factory reset?
With the tv off, press on the remote Mute,1,8,2,Power
This enters the service menu.
The factory reset option is in there.
Aug 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Sony DVP-FX820 DVD Player Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
