Question about Canon PIXMA MX310 All-In-One Printer
Canon mx459 does not scan - Canon PIXMA MX310 All-In-One Printer
How to connect my canon mx459 to my tablet
Via USB is the best way unless the printer has Bluetooth.
Jan 18, 2017 | Tablets & eReaders
Trying to use adf but tells me to put original on platen
You need to check the settings for scanning. The machine wants to use the platen because that is what it has been set up to do, or you are using a sheet size the machine doesn't know about. Again go through the scanner settings both on the machine and any attached computers.
Sep 04, 2016 | Canon Pixma Mx459 All-in-one Inkjet...
Cannon mx459 will not feed copies at ALL!!!!!. hAVE TO PLACE ALL COPIES ONE AT A TIME TO COPY. DO NOT HAVE TIME FOR THIS
Your ADF feed rollers are worn or dirty. Clean or Replace the rollers and it should pick up pages again.
Oct 13, 2014 | Canon Pixma Mx459 All-in-one Inkjet...
How to fax using canon mx459 all in one
Start by connecting it to your phone. Until you do that, it's not a fax.
Now put the document you want to fax in the document feed tray.
Push in buttons to dial phone, and away it goes. It's pretty easy.
Sep 11, 2014 | Canon Wireless Office All-In-One Printer...
Where is WPS button
canon mx459 printer instructions say hold down WPS button, can't find such button, where is it please?
Jan 11, 2014 | Arris SURFboard SBG900 Wireless Router...
How do I reset the language on my Canon MX459 printer?
You can change this from the printer setup by carefully timing the steps and counting your button presses.
First press Setup (at the top of the keypad) and wait about 5 seconds. Then press the Right arrow button once and press OK. Then press the Right button twice and press OK. Press the Right arrow repeatedly until you reach the end of the menu options. Press OK. Press the Left arrow once and press OK. Press the Left or Right button to select your printer's display language and press OK. Then press Stop to exit the setup menus.
I hope this helps.
Dec 27, 2013 | Cannon Office Equipment & Supplies
Canon Printer Printouts with Disappointing Results
First off...its new. Second...its under warranty and any time you mess with it, the warranty could be void. Contact the company for a replacement.
Jan 31, 2018 | Canon PIXMA Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
125 people viewed this question
old marine
old marine
