Question about Electrolux IQ-Touch EIMED55IIW 27" Electric Dryer with 8.0 cu. ft. Capacity, 11 Drying Cycles, IQ-Touch Controls, Perfect Steam Option and Gentle Tumble Dry System: Island White
EIMED55IIW E64 ERROR CODE
WHAT IS ERROR E 64 FOR
Royal Cash Register 120 CX
we'll find that for you..in meantime, try not to run any transaction, eh?
Mar 19, 2008 | Office Equipment & Supplies
E64 error code electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
Aug 09, 2014 | Electrolux Dryers
What does error code 64 mean?
Hello Friend, this is Z. Thank you for allowing me to assist you!
An error code E64 is associated with the heater circuit in the open position. A technician would typically check the heater coils and connections for short circuits to the cabinet to determine if this is the cause of the error code. Depending on the readings, the heater and/or wiring will possibly need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis to help reduce the risk of unnecessary parts. I hope this helps explain the error code you are receiving.
Jul 27, 2014 | Frigidaire Affinity ATF6000F Front Load...
What is error code E64 and how can it be fix
Good Afternoon Friend, this is Z. Thank you for your inquiry!
Normally error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Jul 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I have an error code 64 on my dryer. I am out of work doing chemo right now. can anyone tell me what the problem is
If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
Below I outline a step by step process to do this on the Frigidaire Affinity, but this guide may help with other dryers, as they basically all function the same way.
A WORD OF CAUTION: You will be handling a lot of thin sheet metal components. Be careful as it is easy to cut yourself on them.
First you'll want to unplug the dryer. Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
http://therandomfix.blogspot.com/2013/07/frigidaire-affinity-e64-error.html
Apr 03, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
My frigidaire dryer is showing E 64 error code, what does that mean?
Hello florekedward - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing
Mar 05, 2013 | Frigidaire Electric Dryer
E 64
Hello christinwogo - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Feb 28, 2013 | Frigidaire Affinity AEQ6000WH Dryer
We are getting an error code 64. What do we do to fix this
Error code E64 means heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and cancel. Hope this helped Tim
May 29, 2011 | Electrolux EIED55H Dryer
Getting a fault/error code E 64
Error code E64 means heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and ?cancel?
Nov 22, 2010 | Electrolux EIED55H Dryer
Electrolux IQ-Touch EIMED55IIW 27" Electric Dryer with 8.0 cu. ft. Capacity, 11 Drying Cycles, IQ-Touch Controls, Perfect Steam Option and Gentle Tumble Dry System: Island White Logo
219 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
