Question about K'nex Semi Truck
Wiring configuration for batteries in 2005 international 9400i
I'm getting no power to my gear box in my 2007 international 9400i automatic 18 wheeler
Hi there I am technical mechanical and electronic engineer mechanic have you check out the grounds all over from to back
Oct 25, 2015 | Cars & Trucks
I have a 2007 international 9400i cummings eng fuel is not leveling only drawing from 1 tank
check for blockage or damage to crossover tube ,or cap on tank vent clogged
Sep 30, 2014 | Cars & Trucks
I have a 2001 9400i internation back brake light won't come on
Check the no brainers first. Fuses, relays and bulbs. If that is not it then you need to get into grounding and wiring.
Aug 30, 2014 | Cars & Trucks
I have a international 9400i. i cannot change which vent blow air. cannot change to defrost. is there a valve that controls this? if so where is it located?
International 9400 9200 9900 heat box is under the passages side seat. That where the heater core location and the ac evaporator blower. You have two control motors under there one control the bunk for hot and cold. The other control front for hot and cold. Defrost vent and front vent is in the dash. My suck on defrost and in floor will open to front vent. I have not locate yet.
Dec 23, 2011 | Cars & Trucks
2004 international 7400 heater fan works but can`t get air to defrost?
Where is a the heat actuator located on a 2004 International 9400i. I have heat thru vents only no defrost could like some advice.
Nov 01, 2011 | Cars & Trucks
K'nex Semi Truck Logo
48 people viewed this question
Top K'nex Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a K'nex Toy Expert? Answer questions, earn points and help others
