Question about Emerson 22" Class LCD 720p 60Hz HDTV, LC220EM2
The image on the screen is too large - exceeds the screen size (horizontally) I'm sure it's the aspect ratio, but I cannot see how to change that.
    Sergeant:
  • Emerson Expert
  • 302 Answers
Check your remote its usually on it
Posted on Dec 29, 2013
DOES NOT FILL SCREEN HORIZONTALLY
You can change how your tv displays in the video setting menu under display. You will have a choice between 4:3, 16:9, 16:10, cinema or automatic. I think to fill your screen the best you should choose 16:10 but this is not going to guarantee that all channels will fill the screen. It still has to do with how it is being broadcast to you.
Jan 25, 2016 | Televison & Video
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Apr 10, 2012 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
Cannot change aspect ratio when im playing a game it cuts off part of the screen
Normal aspect ratio is 4:3, and the wide aspect ratio is 16:9. If you play a game meant for 4:3 and you change the TVs aspect ratio to 16:9; part of the picture will be cut off. It is not the fault of the TV.
Oct 15, 2010 | Sanyo DS27800 27" TV
Picture size exceeds TV screen
If you are also using a Cable Box, make sure that the zoom selection, (Format) ,on the Cable Box remote is set properly. Especially if the TV Remotes Aspect Ratio is set to a Wide Format.
Hope this helps,
Skyassoc
Oct 20, 2009 | Televison & Video
How can I make the picture size fit the screen? I loose picture around the edges. Seems like it is displaying at a larger size
The issue your having is aspect ratio. Some programs and commercials are broadcasting in a higher resolution so some fill the screen and some have black bars top and bottom. I suggest searching "aspect ratio for video". It would take me all night to type it out. But you need to know how the different resolutions change the size of your image. Also in the TV's menu you should see an aspect ratio option. Try the different settings to see if you can find the best.
Aug 19, 2009 | Zenith A25A23W 25" TV
Sending photos as an e-mail attachment
When sending photos as e-mail attachments, the image (file) size should not be too large. Use the included image viewing program called Image Expert to save photos in reduced size. For instructions on installing Image Expert, see "Installing the image viewing program" on page 42 of the Instruction Manual. 1. Launch Image Expert. 2. Choose "Open Image" from the "File" menu. 3. Specify the image you want to reduce, then click "Open". If the camera is connected using the USB cable, it is displayed as a removable disc. images on the camera can be opened directly by specifying the remove-able disc. 4. Click on "Change Size" in the "Image" menu. 5. Input values at "Width" and "Height", then click "OK". If "Keep Aspect Ratio" is checked, the size is changed without changing the image’s vertical:horizontal ratio. 6. The image is displayed at its new size. 7. Click on "Save As" in the "File" menu to save the image with the new size.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Emerson 22" Class LCD 720p 60Hz HDTV, LC220EM2 Logo
76 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
