Question about Apple eMac G4 Desktop
Emac ethernet Hi  I had the ethernet working on an older version of Tiger but since upgrading to 10.4.10 it has stopped
  • longspoon Oct 19, 2007
    Thanks - tried everything but it appears my ethernet socket must be faulty or is not being recognised by the software
  • macuser40 Jan 05, 2008
    Have the same problem with the internet connection. Comcast was out telling me the connection on their end shows their modem works, but I still cannot connect to internet. Tried resetting modem, disconnect everything, etc. Still nothing. Comcast said my emac needed a new video card? Does that have anything to do with ethernet connection?
    thanks,
    Novelist:
    Champion:
  • 382 Answers
An update would not prevent the machine from accessing a server, unless other changes in the machine configuration was made. If you are running Tiger (10.4) go tot he apple on the top left, 4 lines down is SYSTEM PREFERENCES. Under INTERNET & NETWORK, you want to select NETWORK. Location should be AUTOMATIC and SHOW should be NETWORK STATUS. From there you should see all the connections in the list below. Next to BUILT IN ETHERNET you should see a color dot either red green or yellow. If the dot is red but there is a cable there, then the cable has gone bad. If the dot is yellow and the cable is in the port, then your computer detects an acgtive signal but your configuration is incorrect, like your ip address is being used by another machine, If the dot is green, then your machine recognizes a stable and active signal. YOu may need to just reset your tcp/ip settings. There are a few more options like unplugging you router for a few seconds, or puling out the ethernet cable from the computer and re-inserting it.
Hope this help
Posted on Oct 19, 2007
Bought a emac at an an local school board auction. It would not connect to internet. Did all of the things in first solution. That did not work, but solution #2 did the trick! Thank you!! I am amazed at the power of the internet and a good search engine. All it takes is the right question/s and perservarance.
713
Posted on Dec 09, 2007
  • 1,006 Answers
Check the FIREWALL if it is ON so turn OFF and try again
SOURCE:
I was using this computer until about an hour ago. Now it asks for a password and won't unlock the screen.
I called the product's support services, and was instructed on how to unlock, and boot up my eMac G4 1.0, OS X version without a startup disk. There are also several safe, and legal sites online that can assist you, with your current issue, hotspot wifi installing plus many other questions, and needs. Hope this info has been helpful in any way, and thank's for asking !
Apr 14, 2014 | Apple eMac G4 Desktop
Upgrading tiger 10.4 What level upgrade is compatible with my old G5 osx 10.4
Version 10.5: "Leopard" is the last to support the G5. Check wikipedia for more details.
Jul 22, 2013 | Computers & Internet
Cant download flash to emac
The eMac uses a G4 processor, and is limited to Mac OS 10.5.x. The most recent version of Flash Player that will run on it is Flash Player 10.1 (if you are running OS 10.4 or later), or Flash Player 9.0.280 if you are still running OS 10.3.
Note that not all web content will work these older versions - in particular, Facebook video inserts will incorrectly claim you don't even have Flash installed instead of playing!
Apr 11, 2012 | Computers & Internet
I have emac 10.2.8 with memory 640mb processor 700MHz power pc G4 . I would like to know what safari version is right one for my computer and where can i get that. plz help me.
Hi SardaIn order to upgrade your Safari you need to upgrade your OS to 10.4.11 at least.Try ebay for a copy. Once you have done that Software Update will automatically offer to update Safari to the latest version applicable.
It's not the machine - it's the OS that matters.
Aug 09, 2011 | Apple eMac G4 Desktop
I just got a used e-mac A1002 (1 Ghz/128/60/combo 56K. It has Mac OS X 10.3.3 installed. I'm having problems signing into G-mail. Facebook also appears as just text. As well, can't seem to play...
I would try and find the OS X Tiger installation disks off of eBay, and install Tiger so that you can at least install Firefox, even if it's an older version. Your computer won't be able to run much, because of the limited RAM, and the fact that the processor is extremely slow.
Aug 03, 2011 | Apple eMac Desktop
Hp laserjet won't print under leopard.
Have you updated to the latest driver, I'm not sure the original driver for "tiger" would necessarily work with "leopard". There is an updated universal driver for all OS X versions.
Just a suggestion.
You can get it here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14991&prodTypeId=18972&prodSeriesId=25478&swLang=8&taskId=135&swEnvOID=219
Jun 16, 2009 | Xerox Phaser 8200 Laser Printer
How do I connect an old G4 Mac (EMac) to the internet...does it have built in wireless?
No you would need a airport card but you can use the ethernet on the side it looks like a phone jack but bigger.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 17, 2009 | Apple .Mac Full Version for Mac
EMac G4 700 512
try to download adobe flash player installer for MAC..
Jan 31, 2009 | Apple eMac G4 Desktop
Unable to upgrade to system leopard on my eMac
With software and computers changing constantly-I use older software for older macs. You will continuously run into problems dealing with new software and old computers. See if you can find older versions that still run great rather than the creative suite. Stick with earlier system software as well. Now days 640 for memory is not much because of the increase in software space use. You can also allocate memory to certain software you use most.
Dec 29, 2007 | Apple eMac G4 Desktop
Apple eMac G4 Desktop Logo
627 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
