Question about Cameras
Hitachi hbc161e what does brackets mean round of hand
Maytag dryer
If this is the metal drum model of Maytag dryer, then the drum is likely out of round and will be evidenced by a broken spot weld on the seam where the drum is welded. I have had to replace mine for that very issue. Not cheap! Hope that is not the case for yours, but just rotate the drum by hand and you will see a high and low spot during the rotation. If the high and low spots are consistent, you know your drum is out of round and likely has busted spot welds. You can run it like that for a while if you can stand the thumping. If no out of round condition, then check the roller alignment and see if the bracket got tweaked not allowing it to rest on the drum. Again...if it touche s the drum and then leaves the drum as the drum is rotate by hand, the drum is out of round. Hope this helps
Feb 15, 2017 | Maytag Dryers
Tip
How to Identify the Type of Bottom Bracket on a Schwinn IC Pro
Video about Identifying the Bottom Bracket on a Schwinn IC Pro Bike
  • This video will help easily determine what kind of bottom bracket you need for your Schwinn IC Pro
  • You see in the video there are four available
    • The first one showed is the OEM style bottom bracket, on both ends it is a square tapered shaft bottom bracket
    • We offer a Sportsmith bottom bracket kit including the crank arms and crank bolts
      • This is also a square tapered shaft bottom bracket
    • We also offer two ISIS style bottom brackets
      • One is a 1 7/8" diameter
      • The other is 1 3/8" diameter
      • As you can see in the video these both have a round splined shaft
      • To identify which ISIS bottom bracket you need you will want to remove the crank arm and measure the hole in the frame that the bottom bracket mounts into
  • You will have to determine if you need a round splined shaft or a square tapered shaft
  • If you do need the round splined shaft you will have to know if you need the 1 3/8" or the 1 7/8" diameter bottom bracket
  • Knowing these things can reduce the frustration of buying the wrong parts and shorten down time greatly
How to Identify the Type of Bottom Bracket on Schwinn IC Pro
on Feb 25, 2015 | Schwinn Ic Pro Indoor Cycle
My unit attaches to a brake with a round ball which snaps into the unit. It won't stay attached any more, keeps falling off of brakes, why ?
Hi, it looks like the bracket that you put the ball into has lost its spring in the plastic that helps to lock the ball . You could try wraping some paper round the ball and pressing it into the hole and see if that holds it in position . You may find a second hand one that the bracket is ok. Or last resort glue it into the position that you use the most.
Dec 24, 2015 | Garmin Nuvi50lm Lower 48 Gps Device
Remove Hitachi RAS-10C2M
there is a bracket that is hung on the wall then the unit is hung on the bracket, it should lift off the bracket by pulling out on the bottom and lifting up. careful of the copper lines. you may want to try connecting a shop vac to the drain line where the water drains, make sure you seal the suction well with duct tape or something and try that first, it should clear it just fine
May 11, 2014 | Hitachi Heating & Cooling
Hitachi hbc161e manual
I took photo's without a memory card in the camera (Hitachi HBC 161E) and thinking i could retreiv them using my usb cable connected the me pc. However when connected the camera remains out of view to the computer. How do I retrieve my pictures
Apr 24, 2013 | Video Cameras
Hi, we have just bought a second hand Hitachi Hi Plasma TV Model PD1, 42PMA400A. We have a wall bracket but what we'd eally like is a stand ... the base plate and two stems that go into the bottom of...
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there from someone who has their TV mounted to the wall and is no longer using it. These are normally fairly heavy and bulky items, so Ebay purchase prices and shipping costs can vary widely.
I did not see any for your exact model of TV available there when I looked, but the online selection changes daily, so you can always keep checking back. Just search on Ebay for 'HITACHI TV STAND' or 'HITACHI TV BASE' and you will see a wide variety of them available for different Hitachi TV models as well as what the average price for them is.
Otherwise you can just buy a generic wall mount floor stand for around $100 which bolts to the TV like a wall mount, but actually sits on the floor instead of being bolted to the wall.
Here are some links to a few different models currently available on Ebay which include pictures so you can see what I mean:
http://cgi.ebay.com/PLASMA-LCD-FLAT-PANEL-MOUNT-TV-STAND-WALL-SHELF-STAND-/390330001764?pt=LH_DefaultDomain_0&hash=item5ae17b2964
http://cgi.ebay.com/Plasma-LCD-Flat-Panel-Console-Shelf-Wall-Mount-TV-Stand-/270797719452?pt=LH_DefaultDomain_0&hash=item3f0ccd479c
I hope that was helpful to you, good luck and take care.
Joe.
Aug 30, 2011 | Hitachi Televison & Video
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
