Question about Insignia IS-LCDTV32 32 in. Television
How do I replace the three 680uf at 35 volt caps at the top left of the power supply board. Where do I get the parts? Step by step instructions?
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
Technika stuck in standby
The standby power supply runs 7/24 and may be part of main power board.
Follow power cord inside to power supply board and as first step examine all the filter caps on it---silver tops should be perfectly flat and not puffed up or leaking brown material top or bottom.
This is the place to begin---see photo of typical cap.
Mar 21, 2012 | Televison & Video
Model FLM-3701 will not power up.
There is a fuse on the power supply board. It is labelled F1. It is a small cylinder near the AC connector. The F1 fuse is 5A 250V. How ever, capacitors are more likely to fail on this television.
The Polaroid FLM3701 has a problem with capacitors failing on the power supply board. If enough caps go bad, you will get no power. Not even a power light.
This P/S board is easy to access on this TV. There is a cover on the back of the TV. It is attached with 8 screws. Remove the cover. This will expose 2 boards. The power supply board is on the right. To remove the P/S board, first unplug the cables. There is an AC power power cord on the right and 4 data cables on the left. The board is held in with 4 screws. Remove the screws and the board will lift out. Any capacitor that is swollen is bad. The top of the capacitor will be curved upward. On the left side of the P/S board, there are 9 big caps labelled E8 thur E17. I would suggest replacing all of them. 6 are 680uF 35V and 3 are 680uF 25V. In the upper central region there are 3 small caps. These go bad, but they do not swell. These are E6, E7 and E22. They are all 22uF 50V. Replace all three. The attached photo shows before and after the caps have been replaced. The original caps were orange. The replacement caps are black.
Dec 07, 2011 | Polaroid Televison & Video
Have a polaroid lcd that fizzled. blue light
This P/S board is easy to access on this TV. There is a plastic cover on the back of the TV. It is attached with 8 screws. Remove the cover. This will expose 2 boards. The power supply board is on the right. To remove the P/S board, first unplug the cables. There is an AC power power cord on the right and 4 data cables on the left. The board is held in with 4 screws. Remove the screws and the board will lift out. Any capacitor that is swollen is bad. The top of the capacitor will be curved upward. On the left side of the P/S board, there are 9 big caps labelled E8 thur E17. I would suggest replacing all of them. 6 are 680uF 35V and 3 are 680uF 25V. In the upper central region there are 3 small caps. These go bad, but they do not swell. These are E6, E7 and E22. They are all 22uF 50V. Replace all three.
Dec 22, 2009 | Polaroid FLM-3701 Television
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
HP VS19e Monitor - no power
There are three (3) capacitors that go bad on the power supply board. MAKE magazine's Instructable site has a good guide on replacing them. I have a june 07 and july 07 date monitors. they were different inside!! identical outside, however. The bulged,'bad' components were 1000uf 10v cap's, I put in radio shack 272-1032 1000uf 35wvdc. My monitors? BOTH were bought for $35 on craigslist, $10.35 in parts. ???BusinFLA -at- hotma*l dot com.....worked for me!
Jun 14, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Insignia LCDTB32 will not stay on
tresalisa,
This is a common problem with this particular model unit and the answer is to replace several bad caps on the power supply module, upwards of 16 caps may have and could fail. There are the main three 680uf/35v caps E919,E920,E921 that usually bow or vent near the regulation circuit, top left of the supply board, replace these even when they appear okay. The remainder can be found simply using an esr meter.
If you have no meter and still want to make the repair yourself remove the board and send it in for repair. That way you'll keep the repair with $200.00 dollars and you've pretty much done it yourself..
Bill
Apr 13, 2008 | Insignia IS-LCDTV32 32 in. Television
Pwer supply board repairs
this model uses 2 different boards--both are not available from Akai (SAMSUNG) look carefully at all the filter caps on the power board--many will be bulged up at the top---last one I did had 20 bad caps---space allowing--replace with higher voltage rated caps---8 were 2200 mfd @25 volt, 4 were 3300 @ 35 volt, 7, 1000 mfd @ 10 volt, and one 1000 @ 6.3 volt---- Sets with 10 digit serial number use one board and sets with 8 digit serial number use another board---I have seen "rebuilt boards" on several sites on the internet for about $115 + S&H---which is about what the original board replacement sold for when they were available.
Mar 26, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Insignia TV doesnt turn on
noavatar_s.png Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Insignia Polaroid Advent Audiovox
ISLCDTV32
lcd
Tries to start then Shuts down!
Insignia IS-LCDTV32 , Polaroid FLM2601 andFLM3201, Advent 203L32K50B Also Audiovox FPE 3205 LC32K5. Cure:Replace the three 680uf at 35 volt caps at the top left of the power supply board.
It works!! I replaced the caps--about a buck each. The bad caps were swollen, and soldering in new caps wasn't hard to do. THANKS!!!
Feb 02, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
341 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
