Question about White Sewing Sewing Machines
Spool pin broke off, need replacement. Model No
Spool pin broke off, need replacement. Model No 4040/4075 Jeans Machine
  • 23 Answers
How to remove broken horizontal spool pin of Singer Sewing machine model 6550 and replace with new spool pin?
It appears to be just "hooked" on according to the photo, and you can get the replacement part for $4.00 using this link: http://www.sewingpartsonline.com/spool-pin-singer-3709-sewing-machine.aspx.
However, before you go to all that trouble, you can also just use the auxiliary spool pin used for twin needle sewing which came with your machine but can be purchased from the same site for about the same price.
I don't use either -- I just put the spool in a cup behind the machine and thread from there. See? One way or another, you're back in business!
Jul 06, 2017 | Singer Sewing Machines
I broke my spool completely off on my brother 350
The spool "pin?" Search for:
Make Model replacement parts
Sometimes you can create a replacement using a plastic drinking straw, a shortened chopstick, etc. On the other hand, there are stand-alone thread holders that can be purchased on the internet. It is usually okay to set a bobbin holder on the table behind the machine.
Mar 19, 2017 | Brother Sewing Machines
How do you replace horizontal spool pin
Hi Phyllis I believe this youtube video will help you, Take care...CHEERS..
https://www.youtube.com/watch?v=abGDVhDlZLs
Mar 17, 2016 | Brother Sewing Machines
The upper part of the right spool pin broke off. I ordered a new pin but am unable to remove the old one to replace it. How do you remove the spool pin?
Depends on your machine brand and model. Some pins simply unscrew and others pull out. Probably best to look at the replacement pin you purchased.
Aug 25, 2015 | Sewing Machines
How do i take the case off my brother xr-65 to replace my spool pin and spool cap
I don't have that particular Brother but I have on that is similar.
Start by taking all of the screws out of the back that you can find (they're in deep holes, so look carefully). Then look at the bobbin area and you'll probably find one more. Finally, take the feet off of the bottom of the machine (not the presser foot, the feet that sit on the table), you'll likely find that there is a screw through the middle of the foot that also holds the case in place.
Best of luck
Sep 10, 2012 | Brother Sewing Machines
Do not know how to replace spool pin and spool cap
It looks like it might just snap into place. Of course that means you have to remove the broken bits which may require a drill, small bit and needle nose pliers.
Sep 10, 2012 | Brother XR-65t Mechanical Sewing Machine
How do I pull up the spool pin?
from the questions I read, this has happened to alot of people.
normally the spool pin should be easy to pull up with 2 fingers, if it's not then most likely there could be something wrong, you can try to use a pair of pliers to pull the spool pin up,, but if it's come loose or broke then it will have to be replaced. and some sewing machine are not mint to be opened by anyone except a factory trained technican.
May 29, 2012 | Brother Sewing Machines
I have a singer machine. Have not used it yet. Got it out of the box by the handle and it looks like the horizonal spool pin broke off. Is this replaceable? Or is this spool pin removable If so how do...
Do you have the manual with it, refer to this to find out if the spool is removable.
if you don't have one, then go to http://www.singerco.com/accessories/manuals.html, type in your model number and click "search" to find it.
Some machines will have two spool holders so you can twin sew but as long as you have one left the machine is useable.
May 23, 2011 | Singer 6510 Sewing Machine
Spool Pin Broke off
Ask you local Singer dealer, be armed with the model number when you call.
Freestanding spool holders can be bought (or made.)
Sep 01, 2009 | Singer 3116 Simple
Broken plastic part within which thread spool pin is inserted
You can search for:
Make Model parts diagram
to see what replacement parts are available.
If not, you can probably devise something to improvise. I've used plastic drinking straws as spool pins, or plastic chop sticks.
Jun 27, 2017 | Janome Sewing Machines
Sewing Machines Logo
342 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
