Question about La Crosse Technology TX37UIT 915MHz Wireless Temperature Sensor
CANT GET OUTSIDE TEMPERATURE 522U - La Crosse Technology TX37UIT 915MHz Wireless Temperature Sensor
Why is my outside temp not registering. I have replaced the batteries
  • Remove all batteries
  • Install outside batteries
  • Move from outside to inside at a casual pace to allow time for outside unit to begin sending temperature
  • Install inside batteries. You should see outside temperature displayed
I find that outside temperature display comes and goes depending upon the weather, e.g., Today at 12 pm, the outside temperature is 35 deg F; earlier this morning it was - -. For the last couple of days, the temperature has been - - then suddenly last night it was 28 deg F.
Jan 30, 2017 | Measuring Tools & Sensors
Where is the ambient temperature sensor located ?
images for 2008 Chevrolet HHR LT Where is the .
Outside Temperature Sensor - Chevy HHR Network
www.chevyhhr.net/forums/...hhr-4/outside-temperature-sensor-30594/
Jul 9, 2010 - I had the outside temp sensor go on my 99 Buick. I don't know where it islocated on the HHR, but it was just a plug in sensor. Take out the old, stick in the new.... 2008 HHR LS 2.2 L Auto Built: 12-19-2007. Bought: 4-26-2009 Location of the ambient engine temperature sensor.... Help ...
Mar 26, 2013
Engine Temperature Sensor
Oct 6, 2011
Outside Temp Display
Dec 19, 2008
Outside air temperature problem
Oct 30, 2007
More results from www.chevyhhr.net
Jan 25, 2016 | 2008 Chevrolet Chevrolet HHR LT
Brand new Blodgett Oven - Cookies over-cooked outside, raw inside.
bad thermostat,just because its new doesnt mean it cant have bad parts
May 15, 2015 | Blodgett DFG100 DOUBLE Convection Oven
How do I reduce the temperature to 16
If constantly works, without stoping then its too hot outside and the temperature cant drop to 16.
Jan 25, 2015 | Haier Heating & Cooling
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire 20.3 cu. ft. / 575 liter...
Outside temperature sensor
The outside air temperature indicator's displayed temperature can be recalibrated. Press and hold the reset select button for 10 seconds . While you continue to hold the button, the display will scroll through temperature settings from +3 to -3. When the desired correction value appears on the display, release the button, and the recalibrated outside air temperature will be displayed. Each time a desired correction value is entered, it replaces the previous value. Give that a try mmkayyy:)
Sep 03, 2013 | 2007 Honda Accord Sedan
Citroen c8 wont start when its cold
probably your crank position sensor is bad. it determines the position of crank and adjust ignition timing. when timing is off it wont start.it cant catch. this is unrelated to outside temperature.
Nov 19, 2011 | Cars & Trucks
I have a bios password in my acer extensa 522u and i forgot it. how can i remove that password?
To reset the BIOS read the information from this link.
In case of your Acer Extensa laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Nov 08, 2010 | Acer Extensa 500T Notebook
Outside temperature reading on my 2009 Chevy Silverado truck is always 4-8 degrees lower than the actual outside temperature.
the outside temperature sensor on vehicles takes the temperature of the air about 2-3 inches off the ground, that close to the ground it might be a couple degrees colder than the temperature on the thermometer you have mounted in the window of your house.
Feb 25, 2010 | 2003 Chevrolet Silverado 1500
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
La Crosse Technology TX37UIT 915MHz Wireless Temperature Sensor Logo
Top La Crosse Measuring Tools & Sensors Experts
john milligan
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
