Question about Health & Beauty
My pampered chef digital thermometer won't work with the probe, the probe temp reads HH, what is it
When I started using it, it worked, then all of a sudden the temp probe temperature went to HH, directions don't say anything about that
3 Suggested Answers
SOURCE: I have a Sunbeam digital
I have the same problem. The problem is the probe went bad. I had a friend with another sumbeam digital probe (the mavrick) put that probe into mine and the temperature reading was working properly. So, now I am looking for a replacement probe. but looks like I will have to just buy another digital meat probe.
Posted on Feb 22, 2009
  • 8 Answers
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Posted on Oct 09, 2010
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Why does wine freeze?
Check for corrosion on the temp probe. The digital displays use thermistors to determine the temp so if the probe has dust on it it will change the resistance reading and tell the cooler that it is warmer than it is. All you can do is clean the probe, and if that doesn't solve the problem then the control or probe are faulty as they are usually one piece you will have to change it out. If you are mechanically inclined you can change out the temp control with an a19 abc24c remote bulb temp control from Johnson controls and that will last of the rest of your life.
Sep 05, 2014 | Danby DWC283BLS Wine Cooler
Oven thermometer only displays lo
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
Dec 25, 2013 | Farberware New Classic Alert Oven Probe...
Probe reads to high compared to my other meat thermometers
Thanks for the great question. While I am a avid smoker and outdoors men I can tell you that most of these gauges are not real accurate and only measure ambient air temp. Also the placement of the gauges in the upper portion of the smokers will give a higher reading because heat rises. My best suggestion is that you use a stand alone meat thermometer for guaranteed great smoked meats. You can also measure the temp inside the smoker using a stand alone thermometer and read your guage at the same time. Than you can use adjust the door thermometer by turning the center of the probe on the back with a pair of plier. You should see a nut head or a locking nut that allows you to hold while you turn the face of the thermometer to recalculate it. Some of these may not be adjustable and you can purchase a adjustable replacement online.
I hope this has given you a better perscpective on these gauges and will help solve you problem.
Oct 06, 2013 | Sportsman Elite 40" Vertical Gas Smoker
How do you use a cooking thermometer to cook pork properly so that it is not raw?
Check out this YouTube video that shows you how to cook pork with a thermometer;
http://www.youtube.com/watch?v=99LW86jQXDs
Feb 14, 2013 | Home
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
I cant get my weber remote thermometer to read the temp.
Note: both the transmitter and receiver unit have a re-set button under the battery compartment lid. If the receiver is not receiving a signal from the transmitter, you will need to disconnect the probe and re-set both units while 'on' before re-connecting the probe.
This is straight off the weber website, and it works coz mine just started reading temp
Jan 08, 2011 | Vacuums
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
    Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
    Aug 16, 2008 | Sunbeam 4214 Iron
    Health & Beauty Logo
    139 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
