Question about Samsung RB215LASH
Reset button for Samsung RB215LABP - Samsung RB215LASH
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: where is the ice maker
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 06, 2011
Owner Manual available on line?
SAMSUNG REFRIGERATOR USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > Refrigerator
View and Download Samsung Refrigerator user manual online. ... Removing the Front Leg Cover First, open both the freezer and refrigerator doors, and then ...
SAMSUNG RB215LABP OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RB215LABP
Refrigerator Samsung RB215BSSW Owner's Manual ... REFRIGERATORRB215LASH, RB215LABP OWNER'S MANUAL In the U.S. for questions about features, ... When you open the door, an item may fall out and cause personal injury or ...
Jan 12, 2016 | Samsung Refrigerators
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
My samsung refrigerator is only a few years old the freezer will not set right , right now it says 27deg's mod number is RB215LABP, can you help me.
first check to see if you have food covering the vents this is the most common problem. with no or very low air flow it will do this.
May 25, 2014 | Samsung Refrigerators
Model RB215LABP water acumulates in veggie bins & on the bottom of refrigerator and freeezes
The drain tube that runs down the back of the fridge into the tray that sits on top of the compressor is blocked, you need to clear this, you can either use compressed air and blow back up into the fridge of find a soft but stiff wire to carefully slide up the tube.
Mar 06, 2012 | Samsung Refrigerators
How to interogate a samsung RB215LABP fridge through the display
I am an authorized Samsung service company, and, according to my diagnostic code quick guide this LED reading should be ignored. It is labelled as an Uart COMMUNICATION ERROR.
I hope this will help you, Ward Appliance Repair.
Dec 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RB215LABP Bottom Freezer Ice Maker..
refrigerator working great then the refrigerator portion went frmo 35deg to 61 freezer is at 4deg can not understand whats up and i cant get the damn thing to do ****
Oct 07, 2007 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung Ice Maker
There is no adjustment for the water level. 9 times out of 10 this problem is with the electric water valve itself. It is not opening all the way, and since the amount of water that is allowed into the ice maker is on a time control, the tray is not filling properly. A new water valve should fix the problem. Not very difficult to install. Shouldn't cost more than $25.00 from an appliance parts store. Good luck, dfink
Sep 17, 2007 | Refrigerators
Samsung RB215LASH Logo
154 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
