Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
My computer will not recognize it.
My computer is not recognize my new usb cord that i just bought.
  • 342 Answers
I would start with attempting to reset the iPod to get it to connect to the computer. If that does not work, attempt to force it into disc mode. And if all else fails try another USB port on your computer or a friends computer. If it does not work try a different cable with your iPod to ensure that it is not just a cable connection :) Below is a step by step on resetting an iPod as well as disc mode just in case you need the information :)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Posted on May 19, 2009
Why won't mu usb cord work for downloading pictures
Here is one possible solution. Some devices require that you use the USB cable that came with the device. Other USB cords won't work. This happened on a Nexus tablet I bought recently. When I tried to charge it with another USB cord, nothing happened. I had to use the exact USB cord that came with the tablet, even though both cords looked identical.
Aug 14, 2014 | Cameras
I bought the HP Deskjet 5650, but I'm not sure how to install it to my home computer.
First find the installation disk that came with your printer in the box. Install the software by placing the disk in your CDROM of your computer and then follow the instructions on the screen. when the software has finished installing, connect your printer to the computer with your USB cord and the computer will automatically do the rest.
Some operating systems already have the driver for your printer and the software is not necessary. To check and see if your computers operating system already has the necessary drivers, just connect your printer via your usb cord. Your computer will recognize the printer once the cord is connected and you will see a pop up message around the right hand corner of the monitor screen that says "new equipment detected" and the computer will do the rest.
Nov 11, 2010 | HP DeskJet 5650 InkJet Printer
I bought a new computer and need to intall my HB deskjet 694C. I bought an adaptor cord to plug it into a usb port. The computer recognizes the cord but not the printer. Any suggestions?
Hello, I have a fail-safe Solution for you... :) Go to the HP Support Website and click on Drivers and Downloads. Choose the 'Scan My Computer' option and make sure the usb cord is connected and the device is turned on. Choosing this method will allow HP to Download and Install Any & All Updated Software as well as Drivers for your HP Devices. Very Simple & Virtually Effortless.. There you go... GOOD LUCK & PLEASE don't forget to rate my Solution. Thanks!! Lucky4lynn2
Apr 26, 2010 | HP DeskJet 694c InkJet Printer
Pictures not loading to computer
It sounds like you don't have software on your PC that will recognize the camera when connected. I am going to recommend that you do not use the camera to upload photos. It is better practice to use external (SD) memory cards and remove them from the camera to upload. You can use a USB SD reader or purchase SD cards with a built-in USB interface. You should be able to see a new drive when connecting the SD card to your computer; then all you need to do is copy over the images. One advantage is that you will save camera battery while uploading because you dont need the camera at all. It also allows you to take images with you without taking the camera, i.e. school or work. I hope this helps...californiajones7889e54.jpg67432f4.jpg4db3d64.jpg
Mar 09, 2009 | Kodak EasyShare C875 Digital Camera
My computer doesn't recognize my new cord for my camera
Try to check if the camera software and driver is properly installed in your computer.
Make sure that your camera is compatible with your computer operating system.
Are you sure you purchased a genuine Samsung USB cord? Because it would be much advisable to use Samsung USB cable.
Try to go to MyAccessoryMall.com and you may purchase the cable there.
Jan 03, 2009 | Samsung Digimax D53 Digital Camera
My computer doesn't reconize my mp3
check if your usb cord if defective.
To check if the mp3 is recognized by the computer go to device manager in the compuer properties.
Go to device manager go to hardware tab and search for new hardware, if you see a question mark in the usb port it means that the computer cant recognize it and you may need a driver. Some mp3 have cd installer of its software. Install it in your computer. and try if the computer can recognize it.
also check if your usb port is working properly...
Sep 16, 2008 | Audio Players & Recorders
Hp officejet 5610 all in one printer
you can use the serial/usb adaptor to connect it to your computer
May 07, 2008 | HP Officejet 5610 All-In-One InkJet...
Sansa mp3
when i plug in my mp3 the computer does not recognize it as being plugged in and there was no software with the player when i bought it
Mar 23, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Computer fails to recognize smt5600
you can use any USB cable, there is nothing specific about any particular brand... now the computer has to recognize the phone. You need the software/driver.
Sep 11, 2005 | Audiovox SMT5600
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
85 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
