Question about RIM BlackBerry Curve 8310 Smartphone
My 8320 doesn't want to respond
When I use the trackball to select by pushing down (Clicking). I've tried replacing the trackball, deleting many programs to free up space, changing the theme to a factory supplied one. Any other thoughts, thanks.
This is becoming a huge problem and i am getting to swear off Blackberry for good.
  • Anonymous May 24, 2009
    I can scroll in all directions and use every other button on my 8310 but cannot select (click) the scroll button, it makes a click sound to show that the device is picking up the movement and you can feel it doin this (so theres nothing stuck or blocking the ball) but my phone is not letting my enter any submenus or aplications, i have got sms mesgs on my phone that i cannout read now and also cant make phonecalls to ppl unless they are already in my call list (pressin the green call button) this is becoming a real pain as i have now tryed everything and am gettin nowhere.
    Scholar:
  • 50 Answers
Usually the button membrane under the track ball goes bad. If you're out of warranty try to remove the trackball and push the membrane back in place if it became misaligned, clean it if necessary. There is a Blackberry Repair Guide that shows how to open a Blackberry and remove the track ball yourself. Once it is open it's as easy as peeling the membrane off the logic board, scratching its bottom with a flathead screwdriver. There are also third party blackberry repair services that will do this for you or supply you with a membrane if you need a new one.
Posted on Jun 10, 2009
The track boll and keyad of my blackberry set 8320is not working i can juat see the screen when wither i fix it on charger or when i remove it can u please tell me some economic solution........?
http://www.truesupplier.com/wholesale-oem-full-blackberry-curve-8300-8310-8320-black-covers-c-890-p-1-pr-19189.html
http://www.truesupplier.com/_search.php?page=1&q=blackberry+8300+trackball
I've purchased items from Truesupplier.com before and they provide excellent service.
You'll need to purchase another keyboard/housing and a trackball for your phone.
You'll need a T6/T4 screwdriver. This can be bought from Lowe's/Home Depot.
There are several videos on youtube that show the replacement of your housing.
This is the easiest way to fix your keyboard and trackball.
May 16, 2011 | Valor Fits Blackberry Curve 8300 8310 8320...
The trackball is not functioning down ward... but the up , left & right was ok. how can i fix this problem
Everyone has the problem like yours. The blackberry trackball will get sticky unscrollable. No need to replace or disassemble. Find out the rotating straw trick at http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
Mar 13, 2010 | RIM Blackberry 8320 Curve Car Charger
Trackball doesn´t move to the right
back your phone up and reflash the software ...you can wipe the s/ware using jl commander
Mar 08, 2010 | RIM BlackBerry Curve 8310 Smartphone
Trackball on my blackberry 8320 will not move to the left. have replace the trackball but the problem still exist
no need to replace or disassemble the blackberry trackball. You can do it from outside of blackberry. Just follow the cleaning trick at http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
Very recommended..
Jan 08, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Trackball on 8320 won't scroll down
the better way is to go to a servicing center
Jul 19, 2009 | RIM BlackBerry Pearl 8100
I want to delete old text messages, how do I do this?
go into message menu highlight message press the menu key(next to talk button) should give you several oprtions scroll down to delete the press trackball should prompt DELETE ITEM select delete all done
Mar 23, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Curve 8330 has a trackball issue
Good evening!
Removing (or replacing) the trackball on the Blackberry phone is very easy.
Shut off your blackberry phone (I would take out the battery).
Quickly examine the trackball itself on your phone. Use something with a small tip, like a screwdriver (NOT A KNIFE! Could damage the mechanism), and slide it underneath the silver ring around the ball. Gently lift up, might also want to try lifting both sides to help lift it off.
Once off, set aside the silver ring. You should now see the trackball mechanism, to remove it, simply flip the phone over and it should just fall out (can also tap it a few times which helps). The mechanism is simply held in magnetically.
You should now be able to see where the trackball was. You can now take a cotton swab with a small amount of rubbing alcohol and clean around in that area. If you examine, you will see small rollers around the trackball, you can also clean these.
This is the best way to clean the trackball. If all else fails you can replace the trackball. You can order one off amazon, they are very cheap, ranging from $2-10.
To put in the trackball, simply reverse the steps. The trackball device only goes in 2 ways, if it simply doesnt fit, turn it. It requires minimal force to put it back in. To put the silver ring back in, just match up the 3 little clips and gently push it back in.
Put the battery back in and give it a test.
Hope this helps!
Feb 26, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Address book
Select the Address Book application from the main screen (with all the icons.) The address book icon is black and white in the default theme.
Press the "Menu" button (just left of the trackball)
Scroll up or down to "New Address" and push the trackball in (select the menu item.)
Fill in all the details that you have for the contact.
Press the "Menu" button again (left of the trackball)
Scroll up or down to "Save" and select it by pushing the trackball in.
Bob's your uncle!
May 28, 2008 | AT&T Blackberry Curve 8300 Smartphone
Trackerball will go up and down,but when you are not able to select anthing.!
You can try these methods.
If you are having problems with your trackball, here are two ways to make it work better.
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Sidekick Skins
Mar 06, 2008 | T-Mobile Sidekick ID Cellular Phone
RIM BlackBerry Curve 8310 Smartphone Logo
230 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
