Question about Sony Handycam CCD-TRV308 Camcorder
Hubby's used it a couple times and has given problems with a piece inside that seems to come out, but that's a whole different issue.
We can't get the tape that's in there out - tape deck door won't open - does anyone know of what to try to get it open??
  • 4,402 Answers
Depends where the tape is located if it's still wrapped around the head i would recommend taking it in if it's inside the cassette you can have to take the door off and see if it pops out.
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
Posted on Jan 16, 2008
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
Has error
It's a supply reel fault. I kid you not, the cure is to give it a REASONABLY FORCEFUL open-handed slap on the tape side. it may take a couple of tries but it works about 95% of the time.
Dec 03, 2007 | Sony Handycam CCD-TRV308 Camcorder
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
Sony Hi8 CCD trv308 NTSC making noise during recording that is audible on playback. Sounds like some moving parts related to turning the tape are not moving as smoothly as they should. Is there anyone...
I had this problem with one of these otherwise very cool cams that I inherited. Something was rubbing on the case of the cassette making a usually faint but audible grinding noise. It is hard to see unless you push the tiny lever on the side of the cassette and flip up the plastic flap that protects the tape. There was a small visible gray grind mark on the center of the case. Now when I buy a new tape I flip open the cassette and carefully scrape away enough plastic on the center of the cassette where it rubs (you can run it a bit and it will grind and show you where) so there is clearance. It worked!!
May 01, 2009 | Sony Handycam CCD-TRV308 Camcorder
Thankyou. I do have the problem solved for now. I found a section about solutions in your web page. Several readers had the same problem. I was about to use a hammer on it but some of your readers came up with idea to slap the camera a couple of times on both sides and by golly it opened up. I was taught to handle sensitive items like the camera with care and to avoid jaring the item, but, this time I was lucky. we will see.
C. Ness
Nov 06, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV128
You have stated the problem yourself - 'I rarely use it'. The electronic and mechanical components within need regular use to stop them failing.
Jul 15, 2017 | Sony Handycam CCD-TRV308 Camcorder
CCD-TRV308 Recording issuses
When was the last time you "cleaned" the heads? Use a good commercial head cleaning tape. They have both "Wet" and "Dry" types. I prefer the "wet" over the dry. I think it does a better job but they are hard to find sometimes.
you can also do it manually with "foam" swabs and "methanol1.gif". Alcohol works but the methanol leaves less residue behind.
If that doesn't solve the problem the next step would be to take it to a repair shop for cleaning and re-alignment.
Jan 29, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony trv308 failure code C:32:22
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Jan 15, 2008 | Sony Handycam CCD-TRV308 Camcorder
Error 3155
have it cleaned by video tech service. might be all it is or could need some tension adjustments. The guy there is super cool.
Aug 15, 2007 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV308 Camcorder Logo
189 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
