Question about Dryers
LSE7806ACE intellidry Just replaced bad 30amp fuse after troubleshooting no-start/heat. Intellidry not working - timed dry does - unit overheats and cuts off if not checked over time. Is sensor bad?
SOURCE: Only heats on timed drying
Our Kenmore dryer had the same sort of problem (different catchy names.
Problem was that in "smart" modes (by what ever name, the timer motor runs in series with a "dampness" sensor (thermostat, actually, I think) and A RESISTOR.
Resistor burns out--this is the symptom set.
Posted on Mar 08, 2009
  • 351 Answers
SOURCE: where is the thermal fuse located on maytag
right with the heating element, first check for 220 volts at the element if you dont get 220 change the fuse if you do get it change the element... i can send you both parts if you visit whirlpoolpartssurplus.com and call me- mark
Posted on Jun 26, 2009
  • 278 Answers
SOURCE: intellidry cycles inoperative, regular timed cycle
Howdy: It seems the "smart switch settings" has died. It is in the switching circuit. It all comes in one unit. Take it out and have it tested at an appliance store. Good luck - Doug
Posted on Dec 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: I have a Maytag Atlantis
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things - thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in plastic housing. If that’s fine then the Heating Element should be checked. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Apr 14, 2010
SOURCE: The gas maytag neptune intellidry gas dryer does
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Posted on Jul 11, 2010
How do i get to my heating element in a intellidry
Well believe it or not just go to YouTube and type in Maytag Intellidry!
Nov 30, 2015 | Dryers
How do i get to the heating element in a Maytag Intellidry model Medx500xl0
Well believe it or not just go to YouTube and type in Maytag Intellidry! You will see a lot of videos on various problems.
Nov 30, 2015 | Maytag Dryers
I have a Maytag Atlantis dryer with intellidry sensor. it will not heat up enough to dry clothes - it just is slightly warm. The sensor always says "damp"
Hi
Thanks
Rylee
Apr 14, 2010 | Dryers
Intellidry cycles inoperative, regular timed cycle is fine ,Maytag Atlantis MDE7400AYW, intellidry sensor shows continunity
Dec 09, 2009 | Maytag Dryers
No heat on my Intellidry?
make sure the control is not set to "air fluff" - check your BREAKERS! if one trips, motor will still run, but no heat, flip them BOTH off and on several times, then try it. if that's not it, check the element and the thermal fuse
Aug 16, 2009 | Maytag PYE2300AY Electric Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Where is the thermal fuse located on maytag intellidry sde505dayw? the dryer tumbles but doesn't dry. no lint or ventilation problems.
Jun 26, 2009 | Maytag PYE2300AY Electric Dryer
Apr 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
Top Dryers Experts
