Question about Pacific Cycle Mongoose 16 inch Go Diego Go Bike - Boys - Dinosaur Mission
Mongoose 16 inch Go Diego Go! Dinosaur Mission Boys Bike seat post pinch bolt
Need to find a new seat/replacement post for 24" Next PX 4.0 Boys Mountain Bike, Black
I am a privet bike repair shop the seat post is a 25.4 mm 9 inch log i have a used seat post in stock and a new seat in stock that will work with a next px 4.0 a had the same issue you contact me on my web site
May 08, 2015 | Next 24" PX 4.0 Boys Mountain Bike, Black
How to adjust the seat on a trek mt boys bike
It could be a hex nut or 9/16 ths bolt. Contact your local bike shop for asistance
Aug 12, 2014 | Cycling
What is the crank bearing size??
Almost all Mongoose models use the standard BSA 68.
I would write a question to them at:
http://mongoosebikes.net/mongoose-bmx-bike/20-mongoose-mode-270-v2-freestyle-bmx-bike/
This bearing should not fail during the normal life of the bicycle, unless the rider weight is over 80 Kg.
Jun 10, 2014 | Mongoose 20" Mode 270 Boys Freestyle Bike
I am wondering where I can order a back wheel for the mongoose 20 inch outer limit boys bike. Accidently got run over and is very bent. Thank you deb
Any Mongoose dealer or bicycle shop should be able to handle that or just web search for a 20" BMX wheel. It doesn't appear to be unique.
Sep 13, 2011 | Mongoose Outer Limit Boys Bicycle Pad Set...
14 or 16 inch boys bike (yellow). How do you raise the seat?
lossen the tighting bolt/clamp and twist the seat up as you pull into the desired hieght, hold and tighten firmly but not over done becuase seat will turn with it...
May 21, 2011 | Cycling
We are not able to fix the seat for the bike,its not getting tight,could u help us ?
Most seats are bolted to the saddle pin with two sets of toothed brackets. If the teeth have been worn off, you'll need to get new brackets.
Apr 18, 2011 | Disney Pixar Cars 16" Bike Boys Huffy...
I recently purchased a 20"
The chain guard is usually fastened to the seat tube of the bike (the frame tube coming up from the pedal area to the seat) with a plastic band. If this band is broken or missing, and there is excessive play in the chain guard, I suggest removing it entirely or returning the bike as it may be a hazard.
Mar 15, 2011 | Mongoose Cycling
Pacific Cycle Mongoose 16 inch Go Diego Go Bike - Boys - Dinosaur Mission Logo
18 people viewed this question
Top Pacific Cycle Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Pacific Cycle Cycling Expert? Answer questions, earn points and help others
