Question about Wildgame Innovations Micro W5ECA 5.0 MP Infrared Digital Scouting Camera
What does NOSD mean on the LCD? - Wildgame Innovations Micro W5ECA 5.0 MP Infrared Digital Scouting Camera
Hi I have tow NSGC2000 trail cameras but if you put it on it only say noSd but there is a cards in. It use to work 100%. Wat can the problem be.
If your SD card is full of pictures or it is used in any other format ,it won't work, format the SDCard with your computer and check whether it works with your trial cam, in some cases there may be dust or clogged dirt inside the memory slot ,use contact cleaner liquid and use a dummy card to push it in and out several times.
Feb 02, 2016 | Cameras
Why is it displaying "no SD" message?
yes, unless two different sd cards could go bad at same time. Bummer.
Aug 30, 2015 | Cameras
Camera says nosd when the same memory card is in it from last year. Tried the other 3 from last year with the same result
Try to check if the contacts in the camera, where the memory card goes in, are still clean and shiny. Only one with a little oxide on it, can spoil the fun. Only try to clean with a dry cloth and or cotton swabs. If you use oil or contact spray, all contacts will corrode much faster.
If you have the skill to dismantle the camera, you even can go farther, and check the whole path from the memory card contacts to the maim board of the camera.
Jun 23, 2014 | Stealth Cam Prowler XT STC-P8XT 8MP...
Eonon installation manual
Just purchased a GA1312 eonon single din android unit. it powers up but screen wont come out, any ideas please?
Jan 16, 2014 | Car Audio & Video
Screen Positioning in HDMI LCD connections
When you say "Projection" do you mean a portable LED projector? If you mean an LCD flat panel display, then you will probably find the resolution you need is more likely to be 1440x900. But, just because your screen says 1366x768 doesn't mean the video output will fill the screen.
May 19, 2013 | Sony VAIO Computers & Internet
Sir in nokia 6085 mini lcd no light , I already changed mini lcd problem same
Thanks for your question. First i have to need to know had you reinstall your phone operation system? that means flash system. but you said you changed your lcd display. that means you hadn't no lcd fault. i think in your mobile motherboard capacitor or diod problems which block your lcd displaying system. please consult in your near any professional technician. thanks
Apr 04, 2011 | Cell Phones
Gateway fpd1760 tft lcd color monitor i not warking
- isolate the problem first by checking all the cables for any bent pins and loose wire/ connections - unplug the lcd monitor and try to get a spare computer to check if its your computer's video card or the lcd monitor - if lcd will give display using a different computer it only means there's something wrong in the computer's video card - if lcd will not give display using a different computer it only means lcd had gone bad and needs to be replaced.
thanks.
Jan 03, 2011 | Gateway FPD1760 Monitor
I have bought few months ago a 4.3" car GPS through Ebay. It operated very well, but today suddenly I found I can not turn it on, although the battery is fully charged. Resetting the GPS I get on the...
It seems that your expert is not really an expert. It took me less than 24 hours, since he told me to junk the GPS, to find the solution through Google, by downloading an update program. May I ask you to reimburse me the 5 USD. Regards. Alex
Aug 17, 2010 | GPS
My new tom tom go 300 gps has nosd card with maps
If you don't have maps, you can't navigate.
So: Get an SD card. Download the maps.
Question for you: How did you wind up with a navigator with no card and no maps? You might consider taking it back to the place you bought it and exchange it for one with the minimum necessary to make it work.
Nov 23, 2009 | Tomtom GO 300 GPS Receiver
Acer 3680
for the guest, it's lcd problem, what you can do is replace lcd, it will solve your problem with line.
for annmarie1122, try to re-seat the lcd cable (that connect lcd to motherboard), it's under middle cover (where power button is reside),
try also to use external monitor. is the display same with lcd ?
if it is same, it's mean your motherboard is bad. if not, it's mean something wrong with your lcd. it could be lcd cable or lcd itself.
May 28, 2008 | Acer Aspire 3610 Notebook
Wildgame Innovations Micro W5ECA 5.0 MP Infrared Digital Scouting Camera Logo
164 people viewed this question
Top Wildgame Innovations Video Cameras Experts
Are you a Wildgame Innovations Video Camera Expert? Answer questions, earn points and help others
